Louvered Doors - Painting - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 08:06 AM   #1
Rewards Points: 2,072
louvered doors
I have 7 bi-fold wood doors with louvers at the top, to paint. As long as I'm buying a sprayer for my fence I wonder about spraying the doors? I plan to do them in the garage.
The paint I'm using from a paint store seems a bit thick. Maybe I could water it down, then put an extra coat on to compensate for the thinner paint?
How does this plan sound?
Startingover is offline   Reply With Quote
Old 06-23-2012, 08:25 AM   #2
DIY staff
Rewards Points: 7,174
What kind of sprayer? What paint?
An airless with the right tip will work with latex--
Old 06-23-2012, 08:31 AM   #3
My trim paint is semi-gloss (latex).
I didn't look closely at the sprayers at the paint store. I just saw they have 2 gal and 1 gal size.
Old 06-23-2012, 09:10 PM   #4
Too Short? Cut it Again!
Floetrol would be better than thinning latex with water. You can get it in quarts and gallons. Follow the label directions. I used it mainly for reducing brush marks but one of its main purposes is for spray applications. Its cousin, Penetrol, is for use with oil-based products if an alkyd primer is part of your project.
Old 06-23-2012, 10:27 PM   #5
thanks.
I just love this site. A person can learn so much here.
Old 06-24-2012, 11:52 AM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
Start adding small portions of water or Floetrol/Extender to the paint. Try not to do it all the paint at once as you can no longer add paint to the mix if you accidentally put in too much Floetrol. You are hardly going to have too thin a coat of paint by adding a small portion of water or Floetrol to it.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-24-2012, 09:57 PM   #7
thanks Matthew.
Sounds kind of like when I cook. You can always add more liquid but you can't take it out.
Interior Louvered Doors nhoj Windows and Doors 10 03-17-2012 07:47 PM
painting louvered doors alphaomega Painting 3 10-29-2011 08:54 PM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
Problems Painting Louvered Closet Doors 1655graff Painting 5 09-08-2009 06:16 PM
