Looking For Primer On Metal Shelf To Use With SW ProcClassic Enamel Waterborne - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 01:32 PM   #1
looking for primer on metal shelf to use with SW ProcClassic enamel Waterborne
Hi,
I am looking for primer on metal shelf to use with SW (Sherwin-Williams) ProcClassic enamel Waterborne.
Thanks,
Tony Dao
TonyDao is offline   Reply With Quote
Old 10-22-2013, 04:24 PM   #2
Rewards Points: 13,446
Zinsser 123
Old 10-22-2013, 05:05 PM   #3
Hi,
Thanks, I read on Zinsser 123 and seems it use mostly on wood. I would like to use on metal.
Thanks,
Tony
Old 10-22-2013, 06:15 PM   #4
http://www.rustoleum.com/en/product-...er-base-primer
Not sure where you read that, but it's wrong.
Old 10-22-2013, 10:54 PM   #5
cdaniels's Avatar
Lots of metal primers out there.Get one for the type of metal you're priming.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Floating Shelf Concerns or Design Flaw? MrChompenstein Carpentry 12 04-14-2013 10:29 AM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Floating shelf on metal stud wall above TV DIY_Jon Building & Construction 0 07-30-2012 03:34 PM
Voltage in the Shower Deacon98 Electrical 32 01-19-2012 04:14 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
