Looking For An Airless Sprayer - Painting - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 10:15 AM   #1
Looking for an airless sprayer
I am looking at getting a paint sprayer and looking for suggestions.
I am going to priming and painting my basement which is approx 900 sqft.
I need to do both the walls and cieling... I am not looking to break the bank and looking to spend about 200 - 300.
Any suggestions?
nsanto17 is offline   Reply With Quote
Old 02-11-2011, 10:34 AM   #2
Rewards Points: 39
Go to:
http://www.gleempaint.com/airspray.html
I got a reconditioned Spray Tech and it worked wonderfully. You'll certainly save a bunch of money.
Plump is offline   Reply With Quote
Old 02-11-2011, 10:54 AM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Any suggestions?
You will want a piston pump, at a minimum .25 gpm, 3000psi, and supporting up to a .015 tip. Spraytech and graco make some good small airless paint sprayers at reasonable prices
housepaintingny is offline   Reply With Quote
Old 02-11-2011, 07:48 PM   #4
Gymschu's Avatar
Rewards Points: 246
What's wrong with rolling and brushing? For 900 sq. ft. it is overkill to buy or even rent an airless. Trust me, you will have it done with a brush and roller faster than any airless can do it. By the time you mask off everything you DON'T want painted and add in time for setup and cleanup, you will be done brushing and rolling.
Old 02-12-2011, 07:47 PM   #5
Workaholic's Avatar
For that size of job you will probably be better off renting, if you have future projects for it then www.spraymall.com had graco 390's for about 6 and a half.
Sean
Workaholic is offline   Reply With Quote
Old 02-12-2011, 10:05 PM   #6
Rewards Points: 256
Hey nsanto17,
gymschu is probably right, it's a neat toy to have but you must be serious about using and cleaning it. If you were doing an entire home with no carpet or flooring then it would pay for itself. Brush and rolling would be the most time saving way to do it. If on the other hand, try keeping an eye out on Craig's List for a used one. Don't even consider buying a used sprayer unless the owner starts it up and see that it will spray at least thinner, better yet, paint. Accept no excuses.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
unsticking an airless paint sprayer chrisusvi Painting 10 07-18-2013 07:54 AM
Airless Sprayer Backrolling Question RickDel Painting 3 08-08-2010 11:15 PM
airless sprayer no suction hoskee Painting 5 07-25-2010 11:39 PM
Airless sprayer help brian_ Painting 3 07-09-2008 01:44 PM
Airless paint sprayer recommendations helpless handyman Painting 7 10-09-2007 05:39 PM
