06-09-2008, 08:23 PM
#1
Little paint problem
Well i painted my washroom ceiling and I had a little area that bubbled and looked real bad. I waited 2 days then i scraped the bubbles off but the paint didnt cure yet. I cleared the area to be fixed but now there is a little paint ridge where the paint and the drywall meets. If i prime 2 coats and paint 2 coats, will that little ridge go away? Should i sand the ridge when its completly dry or wait a day, mud then sand?
06-09-2008, 09:21 PM
#2
Tired, Cold, and Damp
Paint colors, it doesn't fill
You'll probably want to sand (or possibly mud, depending...) out the ridge when it's dry and cured
06-09-2008, 09:22 PM
#3
Drywall and Painting Pro
Maybe get a spray can of Kilz and lightly spray the affected area. Let dry. Repeat the Kilz step. Let dry. Mud. Let dry. Sand. Prime/check mud work. Repeat mud if needed. Prime, If re-muded. Then Paint.
Checkout some of To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
06-09-2008, 09:43 PM
#4
Well i think after the 10th coat it might fill
Your right, i had a hunch but im no painter. I primed it tonight so that i can mud and not have the edges pull off some more.
06-10-2008, 02:00 PM
#5
Another DIY Zombie
'Aint this fun?'
06-10-2008, 03:52 PM
#6
Man im about to pull my hair out!
Yesterday i did a light sanding to get the paint that was coming off and not to pull anymore off. Then I cleaned it and put a coat of primer so that when i put mud on, it has a little layer so not to keep peeling the existing paint off.
Today i went to put a thin coat of mud on, went on nice, didnt disturb the paint already there. 10 minutes after i look at it, theres bubbles on the mud now!
Is this due to the paint underneath not being 100% cured? what should i do?
06-10-2008, 08:25 PM
#7
Could be
Could be you didn't mix you mud
Could be moisture from the other side
Is there a shower or bath tub in there?
An exhaust fan?
06-17-2008, 04:47 PM
#8
Well i waited and tried everything and was still getting bubbles, even when i was putting mud to fix the problem. I returned to the store and explained my problem and the guy gave me an oil primer. So what i did was primed the area with the oil primer, waited till it dried, put my mud, dried, sanded, primed twice and everything looks much better.
06-17-2008, 09:13 PM
#9
Thanks for the update
06-17-2008, 10:01 PM
#10
I thought that might work.
06-17-2008, 11:13 PM
#11
You said:
"Well i painted my washroom ceiling and I had a little area that bubbled and looked real bad. I waited 2 days then i scraped the bubbles off but the paint didnt cure yet."
Was this a latex paint that was applied?
If so, is there any reason you can think of why it hadn't fully "cured" in two days? Was it very humid in the bathroom at any time during the two days that the paint was trying it's hardest to dry? Was the ceiling cold because of cold outdoor weather?
Or, was it a heavily tinted paint? And by that I mean, was it a deep colour, like navy blue or ruby read or canary yellow instead of an off-white colour like powder blue, light pink or "Hint of Saffron"?
If you were using that bathroom for bathing while the paint was drying, and expecially if the paint was a heavily tinted colour, the paint bubbled because it wasn't "curing" properly.
(I'll probably explain this in another post, but latex paints don't "cure" unless they're a cross linking floor paint. Latex paints form a film by a physical transformation (kinda). It's that physical transformation that makes latex paints darken as they dry. Lots about this some other time if and when you want.)
06-18-2008, 11:01 AM
#12
hehe, im sorry i didnt know the type of primer you had suggested was oil based. Should of googled it.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
