Liner To Cover Old Wallpaper Covered W/paint - Painting - DIY Chatroom Home Improvement Forum
Old 05-23-2009, 11:58 AM   #1
Haste Makes Waste
Liner to cover old wallpaper covered w/paint
What is this paper andwhere do you find it?
saggdevil is offline   Reply With Quote
Old 05-23-2009, 03:20 PM   #2
What?? I dont understand your question. Try again and I will see if I can help.
texas115115 is offline   Reply With Quote
Old 05-23-2009, 03:36 PM   #3
Haste Makes Waste
Liner to cover old wallpaper w/paint
There was a response to an earlier question asking about old wallpaper with layers of paint that had cracked. The response said if it is too bad to cover it with paper liner then paint.
Old 05-23-2009, 06:50 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
If it is that bad, completely remove, re-rock or over-rock
(remove everything to the bare walls, tear out the old walls and re-sheetrock them, or simply attach new sheetrock right over the existing walls)
With layers of old wallpaper and layers of paint over that, it's truly a "remove all" or "over-rock" type situation
slickshift is offline   Reply With Quote
Old 05-24-2009, 08:16 AM   #5
Hmmm
I dont know about a lines. I would think that you should remove any loose materiel, then score the walls and float them and panit them.
Built a covered patio, now I'd like to cover over the stucco. Ideas? perpetualjon Building & Construction 7 03-23-2009 11:31 PM
wall liner over wallpaper? RunningGirl General DIY Discussions 5 01-28-2009 03:15 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
How many layers of wallpaper is too many? dumbunusedid Painting 14 07-19-2008 05:48 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
