Linen Cloth Over Plaster Walls And Ceilings - Painting - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 08:43 PM   #1
Linen cloth over plaster walls and ceilings
My house is really old and has linen cloth on the walls and ceilings. Both walls and ceiling are painted but all the paint is cracked off and the ceiling has ALOT of cracks in the plaster under the cloth. Im afraid to take the cloth off of the ceiling cause I dont know what other problems are under there. Does anyone know anything about this stuff cause Im lost and very nervious to do anything to it?
shrtncrzy1109 is offline   Reply With Quote
Old 02-07-2011, 01:00 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Call in a REAL plaster guy. It is probably fine under the cloth, but you never know till you remove it.I have removed my share of this stuff and for the most part only needed minor repairs, but.
Old 02-07-2011, 03:52 AM   #3
That linen cloth is Sanitest. It's just old wallpaper, which comes off like a breeze. Old plaster does have a tendency to spider crack (varicose vein look). If the walls are badly spidered, you could call a wallpaper guy to put liner on the walls, which you then prime, spackle the seams, and paint. That treatment will make the walls look like brand new drywall. But, you'll still have to repair the major stress cracking. Or, as chris said, call a plaster guy if you want to maintain the old, original look. Once all the paper is removed, you might find the plaster, as a whole, is not that bad.
Joe
DiyPaintingGuide.org
The Following User Says Thank You to jsheridan For This Useful Post:
shrtncrzy1109 (02-26-2011)
rewiring house with plaster walls mattrussin Electrical 3 09-27-2010 07:41 AM
Paneling Over plaster walls? Mecca421 Remodeling 4 05-27-2010 06:20 PM
Should I insulate Walls and Ceilings or not? williamj001 Building & Construction 6 07-24-2009 10:37 AM
How to Redo/Replace plaster wall's dcd22 Remodeling 9 06-06-2008 05:37 PM
Ceilings and walls??? Tdoggy187 Carpentry 22 02-29-2008 10:07 AM
