LindsyLoo
If you use TSP, yes, be sure to rinse well. And use a quality bonding primer. How old is the home Lindsy? I'm assuming this is oak panel as opposed to the thin sheet paneling that looks like oak. In older homes a lot of paneled wood was waxed and buffed, prior to poly finishes. Take a piece of 100 grit sandpaper and sand some of the wood. If it was waxed the sandpaper will begin to clog with wax. I would try that and get back with the results.
Joe
