-   -   light blue paint over dark brown paint? (http://www.diychatroom.com/f4/light-blue-paint-over-dark-brown-paint-122197/)
kaity123 11-02-2011 06:22 PM
I have dark brown walls that I will be painting with a light blue from Benjamin moore's regal line. should I use a primer before? & how many coats should I apply?
also! will white ceiling paint be okay to paint on a regular wall?
thanks for your help (:
Brushjockey 11-02-2011 07:31 PM
Paint over paint ( As long as it's not latex over a shiny oil- in which case curtain prep is needed) should not be a problem. And the regal will give better coverage than a primer. Expect 2 good coats.
Ceiling paint is super flat with no durability- not recommended for walls.
user1007 11-04-2011 06:00 PM
Hugh? Curtain prep?:eek:
A finish coat will give better coverage than a primer?:laughing:
Sealers/primers/undercoats serve different purposes than your finish coats. Regal is a great finish coat. It is not a primer and 400 coats of the stuff will not replace a primer if you need one. :thumbsup:
DrHicks 11-04-2011 10:15 PM
If this was my room, I would use 1 coat of primer - for both adhesion and to help hide the dark brown. Then I'd figure on 2 coats of paint. BM is good paint. It'll do a nice job.
Do NOT use ceiling paint on your walls. It's not formulated for that.
Good luck!
Brushjockey 11-04-2011 10:22 PM
looll Curtain- certain - typing is not my first language!
chrisn 11-05-2011 03:35 AM
Who's Hugh:huh:?
Brushjockey 11-05-2011 06:35 AM
Hugh Manatee?
