Old 03-20-2007, 03:50 PM   #1
lead based paint detectors
I have never tested paint for lead. My local hardware store (Lowes) has a paint tester kit and I'm wondering how accurate this is. I bought a 2nd house and am remodeling it, not sure when paint was applied but likely after the 70s. Anyway, I'm just wondering if they're as accurate as a pregnancy test :-) or less.
Samuel
samf is offline   Reply With Quote
Old 03-20-2007, 09:24 PM   #2
From my limited research...
no the commercial "swabs" are not very effective as they only test the surface of the paint They're a good start if you got a few bucks to spend, but in no way are they conclusive. As long as the paint is in good repair, you're usually ok. If it is flaking or "dusty" then you need to do something about it.
They make special sealant paints to coat the lead paint with.
elementx440 is offline   Reply With Quote
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Hi, I'm Doug I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for your today on Expert Village. Now we are going to spray the metal flake. You can see that Dan has applied the base coat the maroon... Read More »
Hi, I'm Doug I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for you today on Expert Village. Candy coat; this has pigment in it but you can see through it. We apply this over the metal flake to... Read More »
Tips for Painting a Ceiling
Tips for Painting a Ceiling by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip we'll be painting our ceiling. Before painting our ceiling we need to remove any object on the ceiling this includes smoked detectors, any types of hooks that might be in the ceiling. In... Read More »
Now, you've painted your gorgeous belt. You just want to make sure that you let it dry free from any dust or dirt. Don't lay anything on top of it. Just give it like a good half an hour to an hour to completely dry. Then in terms of caring for your belt... Read More »
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
lead paint - remove or cover? teresa17603 Painting 8 10-26-2006 07:14 PM
getting paint off of baseboards ><(((jan(((D> Painting 21 09-03-2006 09:23 PM
paint/ oil based poly ? thecrew74 Painting 6 05-19-2006 07:49 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
