Laytex On Laytex Is Peeling.. - Painting - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 10:46 PM   #1
Laytex on Laytex is peeling..
My landlord decided to hire a pro painter to repaint our place, as we are moving out. We painted the entire main floor with a fairly expensive SemiGloss Laytex paint, and when he was here fairly rapidly determined it was not adhesive to the original paint. He tested the original with nail polisher remove, and said it was Laytex paint and not oil. All the walls in the house was peeling, but the original paint was still holding up fine.. In the future, is there anyway to determine what the issue was. I have no idea if the wall were primed, or what paint was used as the original owners left nothing behind.
AzraDark is offline   Reply With Quote
Old 06-29-2012, 04:29 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Improper prep, cheap paint, semi gloss on the walls?
The Following User Says Thank You to chrisn For This Useful Post:
user1007 (06-29-2012)
Old 06-29-2012, 06:52 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Acetone (i.e. nail polish remover) isn't the correct thing to test with. Acetone will dissolve oil paint nearly as easily as latex. Denatured alcohol would have been a better test. It will dissolve the latex but not the oil.
Darkling Designs
poppameth is offline   Reply With Quote
Old 06-29-2012, 07:11 AM   #4
Too Short? Cut it Again!
This gets my vote.
Sent from my 4G capable toaster oven. Made in Virginia.
Old 06-29-2012, 05:12 PM   #5
chrisn's Avatar
Rewards Points: 234
As poppa said use a denatured alcohol or Goof Off to see if the original coat was latex, I am betting it was oil
Tags
laxtex , paint
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 04:17 PM
Latex pain peeling in some areas. Primer came off too! Odd problem... PolishPaul Painting 8 07-29-2011 05:59 PM
Paint peeling issue MadMax99 Painting 6 12-18-2010 04:19 AM
repairing paint that is peeling from plaster walls? infernojmd Painting 4 01-15-2010 12:18 AM
