Old 11-07-2011, 05:18 AM   #1
Red face
Latex Primer over Oil Base Paint on ceiling
Hi i just realized that my ceiling was painted with an oil base paint . It is a very very light yellow color, i already primed it with Zinsser 1 2 3 water base but i didn't sand now im worried that my ceiling will start to peel, it hasn't bubble up or anything and i only put one coat of primer since it was over a light color paint, but i don't know if i should put a second coat of primer keeping in mind that it is over oil base paint. What do you recommend? then im going to be painting it with Sherwin Williams Duration paint 2 coats.
THANKS!
LynniieRockz is offline   Reply With Quote
Old 11-07-2011, 06:01 AM   #2
paper hanger and painter
chrisn's Avatar
Go ahead and paint, the 123 will bond to the paint. It would have bonded better with a little sanding but on the ceiling you should be fine.
The Following User Says Thank You to chrisn For This Useful Post:
ltd (11-07-2011)
Old 11-07-2011, 06:39 AM   #3
Agree with monsieur.
Old 11-07-2011, 02:53 PM   #4
Cool
So with that said... There is no need for a second coat of primer right? Wow my arms are so sore from painting
Old 11-07-2011, 04:46 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
You are good to go for finsh paint- only 1 coat of primer needed.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 11-07-2011, 05:21 PM   #6
chrisn's Avatar
I guess I am never going to hear the end of this
Old 11-07-2011, 09:15 PM   #7
I'm really curious why you'd be using Duration as a ceiling paint.
jeffnc is online now   Reply With Quote
Old 11-08-2011, 08:49 AM   #8
A Little Of Everything
THANKS!
There's a slight possibility that the primer won't bond perfectly, but it's very slight. You should be good to go.
Out of curiosity, why are you using Duration instead of Ceiling Paint? It'll work fine, but my curiosity is showing...
DrHicks is offline   Reply With Quote
Old 11-08-2011, 01:10 PM   #9
Windy Painters
Windy Painters's Avatar
Send a message via Skype™ to Windy Painters
I always prime oil0-based paint with Zinsser 123. Recently I started to use 123 Plus - covers most of water stains too. It may not be enough for greasy spots - in that case Cover Stain would work better but I think you are good to go.
Chicago painter
Windy Painters is offline   Reply With Quote
Old 11-09-2011, 07:40 PM   #10
Matthewt1970's Avatar
I would always opt for oil primer over oil paint but 123 is a really good latex primer. I will alo question the Duration choice on the ceiling. Way overkill for the application.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 11-12-2011, 06:55 AM   #11
Arrow
I dont know i think ceiling paint is too flat maybe ? And it would probably get dirty more easily, maybe im wrong? =\ oh well i will make sure i use ceiling paint when we get to paint the entire house on summer. It was my first time painting with good quality stuff, i missed that one thing though (ceiling paint). But for the first time i think it hasnt been that bad except very painful! sore arms, bruises on legs, bones hurt! Ouch.. hahaha. For those of you who are professional painters, does your body get use to it? =\
Old 11-12-2011, 07:51 AM   #12
Work through the pain. The doctor told me my neck is thirty years older than me.
Old 11-12-2011, 08:35 AM   #13
chrisn's Avatar
After 9 hours of ceilings yesterday,I kind of know what you mean and the good DR was being too kind
Old 11-12-2011, 08:50 AM   #14
I was on the other end of things yesterday. Laying laminate flooring, but not for 9 hours. Dang!
Old 11-12-2011, 09:35 AM   #15
At least things are looking up chris!!
Tags
oil base primer
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 10:06 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
