-   -   Latex Primer over Oil Base Paint on ceiling (http://www.diychatroom.com/f4/latex-primer-over-oil-base-paint-ceiling-122625/)
LynniieRockz 11-07-2011 05:18 AM
1 Attachment(s)
Hi i just realized that my ceiling was painted with an oil base paint :furious:. It is a very very light yellow color, i already primed it with Zinsser 1 2 3 water base but i didn't sand :eek: now im worried that my ceiling will start to peel, it hasn't bubble up or anything and i only put one coat of primer since it was over a light color paint, but i don't know if i should put a second coat of primer keeping in mind that it is over oil base paint. What do you recommend? :huh: then im going to be painting it with Sherwin Williams Duration paint 2 coats.
THANKS!:)
chrisn 11-07-2011 06:01 AM
Go ahead and paint, the 123 will bond to the paint. It would have bonded better with a little sanding but on the ceiling you should be fine.
jsheridan 11-07-2011 06:39 AM
Agree with monsieur.
LynniieRockz 11-07-2011 02:53 PM
Thanks!!
1 Attachment(s)
So with that said... There is no need for a second coat of primer right? Wow my arms are so sore from painting :(
Brushjockey 11-07-2011 04:46 PM
You are good to go for finsh paint- only 1 coat of primer needed.
chrisn 11-07-2011 05:21 PM
I guess I am never going to hear the end of this:no:
jeffnc 11-07-2011 09:15 PM
I'm really curious why you'd be using Duration as a ceiling paint.
DrHicks 11-08-2011 08:49 AM
THANKS!:)
There's a slight possibility that the primer won't bond perfectly, but it's very slight. You should be good to go.
Out of curiosity, why are you using Duration instead of Ceiling Paint? It'll work fine, but my curiosity is showing... :)
Windy Painters 11-08-2011 01:10 PM
Good to go
I always prime oil0-based paint with Zinsser 123. Recently I started to use 123 Plus - covers most of water stains too. It may not be enough for greasy spots - in that case Cover Stain would work better but I think you are good to go.:thumbsup:
Chicago painter
Matthewt1970 11-09-2011 07:40 PM
I would always opt for oil primer over oil paint but 123 is a really good latex primer. I will alo question the Duration choice on the ceiling. Way overkill for the application.
LynniieRockz 11-12-2011 06:55 AM
Why i used duration
1 Attachment(s)
I dont know i think ceiling paint is too flat maybe ? And it would probably get dirty more easily, maybe im wrong? =\ oh well i will make sure i use ceiling paint when we get to paint the entire house on summer. It was my first time painting with good quality stuff, i missed that one thing though (ceiling paint). But for the first time i think it hasnt been that bad except very painful! :( sore arms, bruises on legs, bones hurt! Ouch.. hahaha. For those of you who are professional painters, does your body get use to it? =\
jsheridan 11-12-2011 07:51 AM
Work through the pain. The doctor told me my neck is thirty years older than me.
chrisn 11-12-2011 08:35 AM
After 9 hours of ceilings yesterday,I kind of know what you mean and the good DR was being too kind:laughing:
DrHicks 11-12-2011 08:50 AM
I was on the other end of things yesterday. Laying laminate flooring, but not for 9 hours. Dang!
Brushjockey 11-12-2011 09:35 AM
At least things are looking up chris!!
