Latex Paint Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 02:15 AM   #1
Latex paint peeling
I recently bought my first home and I have decided to change up some colors. The fire place mantle was an off white color. I went to lowes and purchased valspar latex paint. I am a newbie to this, but I just painted over what was already there. After it dried it peeled right off with ease. Someone told me to strip what i painted off and sand down the original paint. Today I did that and repainted a portion of the top. I let it dry and sat something down on it when I picked it up the little rubber feet left marks on the paint. I took a screw driver and scraped it to see if it would peel again, but it didnt like before. I'm pretty much lost on what I need to do here.
luder027 is offline   Reply With Quote
Old 12-19-2011, 04:18 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Latex paint needs 30 days to cure to its full hardness.
Old 12-19-2011, 08:04 AM   #3
Gymschu's Avatar
Rewards Points: 490
When in doubt, PRIME WITH A BONDING primer to ensure adhesion to the old painted surface. Scuff sand, remove dust, and prime with 1-2-3 found at any paintstore or big box store. Then, listen to ChrisN, let the paint cure properly before setting stuff onto the surface.
Gymschu is online now   Reply With Quote
Old 12-19-2011, 09:59 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
Also - some paints are made for trim and dry harder with less stickiness ( painters call that blocking).
Cheaper semis are the worst.
If you really want to use a quality product- get a waterborne enamel at a real paint store.
There is a difference in the quality of the ingredients.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (12-19-2011)
Old 12-19-2011, 02:44 PM   #5
Rewards Points: 394
Regardless of where you buy the product, prep is necessary to achieve proper bonding; the primer idea is a good one. Most architectural paint products (wall/trim) will "block" early in the curing process. Two ways to avoid this: apply a waterborne industrial product, or apply a porch and floor product, which dry to a harder film.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
Gymschu (12-20-2011)
peeling latex paint slappyhoeman Painting 1 09-17-2010 06:28 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Latex paint over Oil Paint Douger_F Painting 10 05-17-2009 10:45 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
