-   -   Latex paint peeling (http://www.diychatroom.com/f4/latex-paint-peeling-127010/)
luder027 12-19-2011 02:15 AM
Latex paint peeling
I recently bought my first home and I have decided to change up some colors. The fire place mantle was an off white color. I went to lowes and purchased valspar latex paint. I am a newbie to this, but I just painted over what was already there. After it dried it peeled right off with ease. Someone told me to strip what i painted off and sand down the original paint. Today I did that and repainted a portion of the top. I let it dry and sat something down on it when I picked it up the little rubber feet left marks on the paint. I took a screw driver and scraped it to see if it would peel again, but it didnt like before. I'm pretty much lost on what I need to do here.
chrisn 12-19-2011 04:18 AM
Latex paint needs 30 days to cure to its full hardness.
Gymschu 12-19-2011 08:04 AM
When in doubt, PRIME WITH A BONDING primer to ensure adhesion to the old painted surface. Scuff sand, remove dust, and prime with 1-2-3 found at any paintstore or big box store. Then, listen to ChrisN, let the paint cure properly before setting stuff onto the surface.
Brushjockey 12-19-2011 09:59 AM
Also - some paints are made for trim and dry harder with less stickiness ( painters call that blocking).
Cheaper semis are the worst.
If you really want to use a quality product- get a waterborne enamel at a real paint store.
There is a difference in the quality of the ingredients.
Will22 12-19-2011 02:44 PM
Regardless of where you buy the product, prep is necessary to achieve proper bonding; the primer idea is a good one. Most architectural paint products (wall/trim) will "block" early in the curing process. Two ways to avoid this: apply a waterborne industrial product, or apply a porch and floor product, which dry to a harder film.
