Latex Over Oil Based Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 09:49 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Latex over oil based paint?
I need to paint a small wall for my dad in his bathroom.
Presently, there is oil based paint and I would like to put a water based paint. Is it enough to sand the wall and then apply the latex paint?
Or is it necessary to prime and then paint?
I do not want to use oil as I cannot stand the smell.
Thanks.
yummy mummy is offline   Reply With Quote
Old 03-07-2011, 10:18 PM   #2
Super Master Painter
Ole34's Avatar
i would sand/prime then paint it ..................use a latex primer if your bothered by the smell of oil products
Ole34 is offline   Reply With Quote
Old 03-08-2011, 06:19 AM   #3
Gymschu's Avatar
Rewards Points: 838
Ole 34 is right again. Scuff sand with a pole sander or a sponge sander, remove dust, prime with Zinsser's B-I-N bonding primer (latex), allow to dry for a day, then apply 2 coats of your favorite latex finish paint. Job done.
Old 03-08-2011, 08:20 AM   #4
Thanks for your help, ole34, and gymschu.
I was hoping to get away from priming it first....
I will get some primer then, and do the job right.
Old 03-08-2011, 01:53 PM   #5
Gymschu's Avatar
Rewards Points: 838
Yummy, I have gambled before with latex over oil & I usually lose. You are wise to play it safe and do it right!
The Following User Says Thank You to Gymschu For This Useful Post:
Ole34 (03-08-2011)
Old 03-08-2011, 03:10 PM   #6
Ole34's Avatar
some people will sand down the gloss and then hit it with latex but like you said about gambling and losing..............its not worth it
Old 03-08-2011, 03:48 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
If it were me, I would prime it with oil. Bin will work too but the smell can drive you nuts and it can dry wicked quick giving you lap marks when brushing.
Old 03-08-2011, 08:04 PM   #8
Bin smells bad???
My dad wants me to just use oil, but I cannot stand the smell.
If Bin smells bad, is there another one on the market that smells better?
Thanks everyone for your help.
Old 03-08-2011, 08:13 PM   #9
ltd
Rewards Points: 536
if its not lead base paint lightly sand walls every inch fine sandpaper . you dont need to go nuts you just deglossing old oil finish . this wont take long .then oil prime zinsser cover stain .you said you dont like the smell .i dont know anybody that does .but imo i would not do it any other way. follow dry times then 2 coats latex.ps if need be cover stain can go right over with out sanding
ltd is offline   Reply With Quote
Old 03-08-2011, 08:56 PM   #10
Gymschu's Avatar
Rewards Points: 838
B-I-N smells no worse than most latex paints in my opinion. If you want to use an oil-base primer use KILZ Odorless.
Old 03-08-2011, 09:00 PM   #11
Ole34's Avatar
i got $^&*^% off of cover stain before while spraying it in a basement ............not fun, me an my boss were outside talking stupid for about half hour
Old 03-08-2011, 11:03 PM   #12
Rewards Points: 526
I would just sand the surface as suggested and use a quality latex primer. I never have any problems doing it this way. The important thing is to use a primer. In my experience it really doesn't matter what type, so long as it is employed as part of a coherent system.
Windows is offline   Reply With Quote
Old 03-08-2011, 11:39 PM   #13
(the original)
Rewards Points: 756
I think you might be confusing B-I-N (pigmented shellac) with Bullseye 123 (all purpose acrylic). I've used a lot of B-I-N for fire restoration and those alcohol fumes will kick your butt if you're not careful.
Bullseye 123 is a good product for YM's purpose. Ben Moore Fresh Start is another good choice. A good cleaning is necessity, a light sanding is insurance.
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
Gymschu (03-09-2011)
Old 03-10-2011, 08:36 AM   #14
I'm holding my fire, still waiting on something in writing on this topic. So far, haven't been offered anything other than anectodotal proof that an intermediate layer is required. Can tell you that I asked this question again yesterday in the paint store, Why do you recommend a primer between latex and oil? Because people don't sand, and they're covering their butt. The old timer standing there agreed. I have never seen the necessity of priming in writing, no where, ever.
Old 03-10-2011, 08:49 AM   #15
You can approach it however you want.
People who have done it and continued to live in the house for 15 years will usually see the issue. You won't peel in the painters warrantee period if that's the discussion.
My father just sanded this mess off of an entire top floor by himself because he was told by latex proponents that you can do as you mentioned 10 years ago.
Today's products may be better, but for the cost, in my own home - I wouldn't gamble on it.
cschwehr is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
