Latex On Oilbased Walls - Painting - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 10:37 PM   #1
Latex on oilbased walls
I have put 3 coats of latex on an oilbased wall and have a peel mark---will I have to redo,by peeling off the paint?, or will it eventually settle?
Pilyk is offline   Reply With Quote
Old 02-24-2012, 03:06 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
settle?
Old 02-24-2012, 06:08 AM   #3
Too Short? Cut it Again!
Generally you can put latex/acrylic products over oil-based (doesn't work so well the other direction) but with any coating over anything you need to prep the surface to maximize the adhesion. And you need to use quality paint. If you tried to paint over a gloss finish without deglossing with chemicals or sandpaper you reduced the surface for the new paint to stick. If you used box store paint it has more water than nice paint store paint and it further reduced adhesion.
Alkyd primers are great equalizers and are often used when switching between oil and latex. Too late for you now but think about a primer layer for future projects. A high bond latex priimer would have been another good choice.
You are probably going to have to peel/sand off the part of the paint that is blistering and bubbling. Skim coat with drywall compound. Spot prime and repaint.
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (02-24-2012)
Old 02-24-2012, 06:46 AM   #4
Gymschu's Avatar
Rewards Points: 668
Not many details given. What brand of latex paint? Did you prep/scuff sand/apply bonding primer like Sdsester said? Did you wait the proper amount of time before applying those 3 coats? Is there any kind of venting, etc. that could be causing condensation/moisture issues inside the wall?
Old 02-24-2012, 06:48 AM   #5
By the way, at this point, adding more coats is not going to fix the adhesion problem at this point.
chrisn (02-24-2012)
oil to latex, proclassic vs behr GLS0628 Painting 2 06-23-2011 05:57 PM
basement wall waterproofing Jenbarkel Building & Construction 9 08-30-2010 05:37 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
