Latex No Stick To Metal - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 08:19 PM   #1
latex no stick to metal
Ok, so I painted a large metal surface with just latex house paint and no primer, It turns out it peels off fairly easly "when I take my fingernail to it" so Im a newbie when it comes to painting and this surface area is fairly large and im trying to avoid not having to scrape off all the paint again. Is there anything I can put on top of this latex that would make it scuff proof, like a wax or Polyurathene? Im just dreading having to take up all this paint. Well, at least ill know for next time. Also, if you could recommend a good metal primer, that would be great. Thanks!
vdubguy is offline   Reply With Quote
Old 03-02-2009, 05:32 AM   #2
Remodeling Contractor
no.. anything you top it with will not help with doing it wrong to start with. Remove it. Latex on metal is a poor job anyway.
Old 03-02-2009, 05:50 AM   #3
the Musigician
DangerMouse's Avatar
what is the large metal surface, and what is it used for? this may help in deciding how to do it correctly.
Bob is correct though, latex is not going to perform for you. you'll need to clean it off.
DM
Old 03-02-2009, 10:41 AM   #4
Rewards Points: 506
I don't think Latex is necessarily a non-starter here. Without primer, yes, but I wouldn't exclude it entirely, depending on job.
SirWired
sirwired is offline   Reply With Quote
Old 03-02-2009, 10:51 AM   #5
the Musigician
true, kinda up in the air until we know what it is and what it's used for. but he's still gotta get the old stuff off...
DM
Old 03-02-2009, 12:25 PM   #6
SDC
SDC's Avatar
You should use a DTM paint when painting metal...
SDC is offline   Reply With Quote
The Following User Says Thank You to SDC For This Useful Post:
hammerheart14 (10-12-2010)
Old 03-02-2009, 12:52 PM   #7
dtm's (direct to metal) come in latex and alkyd Its basically all we can use (latex dtms)on government jobs now
torpainter is offline   Reply With Quote
Old 03-02-2009, 12:53 PM   #8
Thanks guys, im just going to remove it. Hot soap and water will prb take it off, just wish I didn't put it on so thick.
Old 03-02-2009, 12:55 PM   #9
try a sharp scraper ,it should just peel away
Old 03-02-2009, 01:03 PM   #10
the Musigician
tor---thanks for the "(direct to metal)" definition as it occured to me many users here don't understand abbv. we use daily and it always helps if people post the definition as to what it stands for. this goes for ANY thread, it's had me googling a couple times for things i never heard of before! lol
DM
Old 03-02-2009, 01:07 PM   #11
I sometimes forget when I am training apprentices .I realiaze when I see the blank stare on their face...lol
Old 03-02-2009, 01:09 PM   #12
DM
Yeah still trying to figure what this one means?
Old 03-02-2009, 01:16 PM   #13
the Musigician
that's a testament to my delightfully fresh breath, it stands for "Divinely Minty"
DivinelyMinty
Old 03-02-2009, 01:30 PM   #14
SDC
SDC's Avatar
DM
Sorry about that
I will try harder in the future...
Latex versus Oil On Bare Metal. Does Latex Cut It? TomBrooklyn Painting 3 01-21-2009 07:36 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
