Old 11-26-2011, 09:23 PM   #1
MikeKy55's Avatar
Latex on fiberglass shower/tub
Our guest bathroon was painted before we bought the house. When they were cutting in around the shower/tub, they got paint out about 1/4 to 3/8ths of an inch in some places. What could I use to remove that before painting again? The PO left the excess paint from that project and it's latex. Thanks in advance.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Old 11-26-2011, 09:38 PM   #2
some sort of plastic scraper
kennzz05 is offline   Reply With Quote
Old 11-27-2011, 09:16 AM   #3
Gymschu's Avatar
Soak part of a rag in "GOOF-OFF", the ultimate remover, put it over the top of a 2-inch or 4-inch scraper and gently rub the latex with the rag-soaked scraper. It will come off rather easily. You want to be careful not to scratch the fiberglas.......that's why you cover the scraper with the rag. Of course, test a small area first to be sure you don't discolor the fiberglas.
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (11-27-2011)
Old 11-27-2011, 10:57 AM   #4
I agree with Gymschu. But I would add that I find it easier to rub some remover on first, allow it sit, maybe refresh it a bit, then come with your soaked rag scraper. Allow it to pre-soften. I've also removed that stuff by scoring a line down with a blade, then getting the blade under and lifting it up to get a hold and peeling it off in one long strip. Or, running the blade under the length after the cut, almost parallel with the surround surface, carefully. Then wipe any remainging residue with the goof off. I like to get as much stuff off dry as possible. I do a lot of that stuff because when you follow a sloppy painter, his mess could easily be attributed to you. I was blamed once for getting paint on the floor, even showing the lady that it was a different color than I was using she wasn't convinced. She said it wasn't there before I started.
Old 11-27-2011, 12:50 PM   #5
MikeKy55's Avatar
Thanks! I have some goofoff out in the garage. I was a little worried how it would affect the resin coating. I'll give it a try.
Old 11-27-2011, 02:43 PM   #6
Gymschu's Avatar
Joe, reminds me of a story........painting exterior windows that were painted shut many times over......I asked the woman if she would like them unstuck.....she says no.....I paint them as they were and finish the job. Two weeks later she calls screaming and crying that I painted her windows shut. I drive out and unstick them reminding her that she told me to simply paint them as they were. Nothing worse than getting blame for something you weren't responsible for.
Removing fiberglass batts without fibers all over house darlingm Insulation 7 09-10-2011 10:47 AM
oil to latex, proclassic vs behr GLS0628 Painting 2 06-23-2011 06:57 PM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 11:16 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
