Latex Enamel Over Latex Semi-Gloss - Painting - DIY Chatroom Home Improvement Forum
Old 07-29-2011, 02:44 PM   #1
Latex Enamel over Latex Semi-Gloss
Is it OK to paint latex enamel semi-gloss over regular latex semi-gloss for trim and doors currently in the regular latex semi-gloss and/or does it need any special prep work?
M910 is offline   Reply With Quote
Old 07-29-2011, 03:34 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I would scuff them first, but you will be fine.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
M910 (07-29-2011)
Old 07-29-2011, 03:39 PM   #3
I think what Matthewt means is to sand the surface to remove the sheen and give the new paint something to bond to. Get some 120 or 150 grit sandpaper and go over the entire surface.
Welcome to the forum.
The Following User Says Thank You to jsheridan For This Useful Post:
M910 (07-29-2011)
semi gloss enamel umcgirl Painting 3 03-12-2009 09:09 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 03:47 PM
