Large Ceiling Application Advice - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2014, 12:11 PM   #1
garlicbreath's Avatar
Rewards Points: 150
Large ceiling application advice
Hi all.
Getting ready to start the paint portion of the project.
Could you please offer any advice on technique?
The ceiling is approx. 25'X27'.
New drywall and mud and tape. 1st coat of mud done. 2 more to follow.
I plan on priming with pittsburgh paint. Seal grip I think it's called and then I will use ppg ceiling paint blue can. (They didnt have gold can??) Quality 1/2 nap roller as well.
Anyway, I hope the product choice will help me in the application.
My concern now is keeping that wet edge over that huge area.
Thanks for your help.
Sent from my Motorola MicroTAC 9800X
garlicbreath is offline   Reply With Quote
Old 03-01-2014, 04:38 PM   #2
Gymschu's Avatar
Rewards Points: 832
That's gonna be one tough ceiling Garlicbreath! Get the best DEAD flat ceiling paint you can find. PPG makes great ceiling paint IMO. You will have to hustle to always keep a wet edge. I would use a 1/2" quality roller cover, either Purdy or Wooster. Load that sucker up with paint for each pass. It should be ALMOST dripping wet with paint after dipping it in your roller tray. Roll in 2 to 3 ft increments. Don't take breaks as you will end up with holidays and lap marks. A dead flat is pretty forgiving and you won't see roller marks unless you press and push the roller through the paint. Let the roller do the work. Reload often. Thats the best advice I have.
The Following 4 Users Say Thank You to Gymschu For This Useful Post:
garlicbreath (03-01-2014), Jmayspaint (03-01-2014), princelake (03-02-2014), ToolSeeker (03-01-2014)
Old 03-01-2014, 04:48 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 392
what gym said and if you can get a 1/2 in microfiber cover all the better and definitely get the gold can, the blue is ok, the gold is better
also, roll the first finish coat. across the ceiling and the second coat long ways
chrisn is online now   Reply With Quote
The Following 4 Users Say Thank You to chrisn For This Useful Post:
creeper (03-17-2014), garlicbreath (03-01-2014), Gymschu (03-01-2014), ToolSeeker (03-01-2014)
Old 03-01-2014, 06:33 PM   #4
Rewards Points: 144
+1 on above.I would roll two coats of primer.One each direction.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
Old 03-02-2014, 06:13 AM   #5
Rewards Points: 5,974
Really 2 coats of primer would serve no purpose. One coat of primer is all that is needed.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
garlicbreath (03-02-2014), princelake (03-02-2014)
Old 03-02-2014, 07:07 AM   #6
Rewards Points: 150
Appreciate all the comments. I am looking forward to painting. I hope I can start in one week.
Old 03-02-2014, 07:41 AM   #7
Rewards Points: 144
I always apply 2 coats of primer on fresh drywall.The primer covers the fresh board and the mud differently.It make for a better looking topcoat.
Old 03-02-2014, 09:46 AM   #8
Rewards Points: 150
Originally Posted by garlicbreath View Post
Hi all.
Old 03-02-2014, 10:15 AM   #9
Jmayspaint's Avatar
Rewards Points: 534
I find that using a primer that really seals well helps on a large ceiling like that. Regular drywall primers do equalize the porosity of the boards, but they still are quite porous to paint over. In other words they absorb some of the finish paint as your painting over them, causing the paint to dry quickly.
Primers like Zinsser 123, Gardz, and Bin, actually seal the surface much better giving you a longer working time with the finish paint.
That only true for the first finish coat though. Once you put a coat of flat on, you have a porous surface again and the second coat will soak in and dry faster than the first.
That is going to be a tough one to paint, all that critical light from the windows is not going to be forgiving at all. If possible i would use a 14 or 18 inch roller.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
garlicbreath (03-02-2014), Gymschu (03-02-2014)
Old 03-02-2014, 11:44 AM   #10
Gymschu's Avatar
Rewards Points: 832
Painting a ceiling like that is also unforgiving to your NECK!!!
Old 03-02-2014, 05:31 PM   #11
Rewards Points: 512
i would find a buddy to help you. roll together with the other guy rolling into where you stopped. i'd also put floetrol into the paint to help with leveling and avoiding lines.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 03-02-2014, 06:55 PM   #12
OK I'll be the bad guy, the room looks empty why not spray? Mask the walls with 9' plastic put extension on gun walk from one side to the other turn walk back. use a 512ff tip 10'fan, little overspray, wet edge all the way.
Old 03-02-2014, 07:42 PM   #13
Rewards Points: 144
That's the way to go.I am pretty good at painting but if I can't spray it I hate it.
Old 03-05-2014, 05:53 PM   #14
Rewards Points: 150
I'm intrigued about spraying. My local rental place got one of these. http://www.rentaltimeonline.com/Pain...r%20pg%202.htm
Old 03-05-2014, 05:55 PM   #15
Rewards Points: 150
89 bucks a day plus tax. Im going to need it for three days minimum. Maybe Ill buy one instead. Used? Then sell when done.
That leads me to my next question. What to buy? I have a compressor if that makes a difference.
ceiling advice needed.... Hila Building & Construction 3 03-24-2013 08:00 AM
need advice wiring a ceiling light jhack836 Electrical 5 01-27-2013 09:04 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Need advice on vaulted ceiling insulation jaminduncan Roofing/Siding 38 05-13-2010 01:52 PM
Ceiling Fan Advice rlynch HVAC 13 08-30-2009 06:37 PM
