Laminate Furniture - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 07:32 PM   #1
laminate furniture
i painted over laminate furniture but the paint is not sticking. i did use liquid sand. if i put a polyurethane over it will it stick
joval is offline   Reply With Quote
Old 01-17-2012, 07:40 PM   #2
Rewards Points: 12,824
Not a great plan, real sanding would have given you half a chance of it sticking for a short time but liquid sand is a joke and never should have been used.
Paint of formica is not likly to work at all for long.
Old 01-17-2012, 09:29 PM   #3
ARC Painting's Avatar
I would invest in new furniture instead
laminate should be sanded and primed with an adhesion primer, if its worthwhile...
if the paint is not sticking, youll need to remove it if you want to move forward.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 01-18-2012, 05:00 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
one word NO
Old 03-26-2012, 07:40 AM   #5
Laminated furniture are good as it protect wood from being spoiled by water or any other bacteria. Yedra provides all types of furniture like wooden furniture, metal furniture, also provides stylish home decors at very reasonable cost.
____________________________
miami gardens furniture stores
brucemoe37 is offline   Reply With Quote
Old 03-26-2012, 08:47 AM   #6
Too Short? Cut it Again!
Melamine paint is designed for painting melamine and laminate surfaces but even so you may have adhesion problems long term. It is not cheap and is a bit of a challenge to work with since it is so sticky. And Melamine is prone to chipping. It does come in factory colors and supposedly there are now at least light color tint bases as well but I have not used them. See what your real paint store suggests.
You might have bought some time with paints for plastics like Krylon Fusion (only comes in rattle cans) or the Rustoleum primer (comes in liquid and rattle cans and you can paint over it with anything) and plastic paint line (rattle cans).
You will have to scrape what you put on off at this point. It sounds like it is coming off on its own so this should not be a major ordeal. You will have to use an actual abrasive and not a chemical to scruff up the surface.
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Painting Laminate Furniture ajinutah Painting 3 10-11-2008 11:11 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
