Old 06-12-2012, 04:56 PM   #1
Question
lacquer primer under Latex
Hi- I was once told that latex paint will peel off of lacquer primer, and to stick with oil based topcoats for interior trim. I love how smooth lacquer sands down, and would like to know if you all agree that you just cant top it with latex
(semi gloss)
behumble is offline   Reply With Quote
Old 06-12-2012, 05:22 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Lacquer in any form is usually a sprayed on coat- what product (primer) are you using, and on what?
Most pre- primed wood is actually a lacquer, and it really sucks as a primer because it has no enamel holdout and needs to be reprimed . Not thinking that what you are using is the same- but I'm no fan..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 06-12-2012, 09:03 PM   #3
thx for that reply B.J.- to answer your ?'s, the primer is from Color Wheel if youve heard of them- theyre down here in FL - and I've used s/williams but didnt get the build I like.
I am mostly using it on pine millwork--
I hear what youre saying about the preprimed trim and agree- thats my concern, if you dont sand and dust- that latex will NOT adhere for crap! especially if you have a large flat surface -vs- complicated profiles
Old 06-12-2012, 09:12 PM   #4
on homes with smoke/fire damage we spray the bare studs and we spray the drywall that is left with bin(lacquer base) then back roll. we then paint with a latex based paint.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
behumble (06-12-2012)
Old 06-12-2012, 10:16 PM   #5
Bin is Shellac based, not lacquer.
Tags
lacquer, latex, primer
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Latex primer over oil base finish.. whalogreg Painting 6 01-28-2011 03:32 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Acrylic Latex Primer vs Latex Primer Saintt Painting 1 08-02-2008 10:00 PM
