-   -   lacquer primer under Latex (http://www.diychatroom.com/f4/lacquer-primer-under-latex-146845/)
behumble 06-12-2012 03:56 PM
Hi- I was once told that latex paint will peel off of lacquer primer, and to stick with oil based topcoats for interior trim. I love how smooth lacquer sands down, and would like to know if you all agree that you just cant top it with latex
(semi gloss)
Brushjockey 06-12-2012 04:22 PM
Lacquer in any form is usually a sprayed on coat- what product (primer) are you using, and on what?
Most pre- primed wood is actually a lacquer, and it really sucks as a primer because it has no enamel holdout and needs to be reprimed . Not thinking that what you are using is the same- but I'm no fan..
behumble 06-12-2012 08:03 PM
thx for that reply B.J.- to answer your ?'s, the primer is from Color Wheel if youve heard of them- theyre down here in FL - and I've used s/williams but didnt get the build I like.
I am mostly using it on pine millwork--
I hear what youre saying about the preprimed trim and agree- thats my concern, if you dont sand and dust- that latex will NOT adhere for crap! especially if you have a large flat surface -vs- complicated profiles
princelake 06-12-2012 08:12 PM
on homes with smoke/fire damage we spray the bare studs and we spray the drywall that is left with bin(lacquer base) then back roll. we then paint with a latex based paint.
Brushjockey 06-12-2012 09:16 PM
Bin is Shellac based, not lacquer.
