Krud Kutter Deglosser - Painting - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 09:41 PM   #1
krud kutter deglosser
I am planning to repaint interior wood trim. It currently has on oil paint and I'm thinking of using Sherwin Williams Pro-Classic latex semi-gloss. Will I get good adhesion with just using Krud Kutter deglosser, and then the SW Prep Rite Pro-Block as primer?
cnwi is offline   Reply With Quote
Old 07-31-2009, 04:41 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 298
I see no reason to use the deglosser if you are using a primer anyway,as long as the trim is clean.A very light sanding first would'nt hurt.
Old 07-31-2009, 05:07 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
The SW Pro Block Oil Alkyd is exactly what you need. If you are changing colors, have them tint the primer.
deglosser joefromcal Painting 3 08-08-2009 07:29 PM
Help with Liquid Deglosser janet.giron Painting 10 07-26-2009 08:23 AM
Can I rescue (clean) a brush that's already dried? Beth777 Painting 14 09-18-2008 05:30 PM
Painting Paneling - Do I need deglosser? sweetsue777 Painting 7 01-30-2007 01:35 AM
