Knotty Pine - Painting - DIY Chatroom Home Improvement Forum
Old 09-20-2012, 02:19 AM   #1
Knotty pine
How do you paint knotty pine walls and ceiling?
Deb Hiller is offline   Reply With Quote
Old 09-20-2012, 02:51 AM   #2
Easy Step by Step
1. First clean walls. Vinegar and Water mix works great on wood.
2. Prime walls with all purpose primer. This will help cover knots and even out surface and make your final coat look nice. If your pine is already painted you can skip the primer. Paint store will tint your primer. Helps with less final paint coats.
3. Use paint of your choice to finish.
honeydolist1 is offline   Reply With Quote
Old 09-20-2012, 05:33 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Pine knots need to be sealed with BIN
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
ltd (09-21-2012)
Old 09-20-2012, 09:09 AM   #4
Too Short? Cut it Again!
If it is new pine, all has to be sealed first. BIN will do it and you need it for the knots anyhow. Otherwise, a mixture of 1:1 PROCESSED not raw lindseed oil and mineral spirits will work as well as anything. Let the solvents evaporate, sand any surfaces that checked in the process, than proceed with BIN.
Note that BIN has a high alcohol content so make sure you have more than adequate ventilation.
Old 09-21-2012, 09:36 AM   #5
Rewards Points: 5,974
If these walls were finished with a clear finish like vanish or polyurethane they will need to be sanded, then cleaned, then primed with the primer above. You will probably find this to be the most expensive primer on the shelf but because it is a stain blocker it will keep the knots from bleeding thru your paint.
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 10:25 AM
Maintain knotty pine walls when repairing bathroom flooring jdowling Flooring 0 07-18-2011 06:19 PM
Can't find studs behind knotty pine paneling David S General DIY Discussions 15 09-05-2010 06:56 PM
Knotty Pine mgortel Carpentry 5 06-21-2010 09:21 PM
HELP!!! Primed Knotty pine... needs to be unprimed! deke44 Painting 2 06-04-2010 04:44 AM
