Knots Bleeding Through New Painted Trim - Painting - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 03:59 PM   #1
Question
Knots bleeding through new painted trim
In my recent bathroom remodels, the door and window trim had some knots. It was primed and then 2 coats of semi-gloss latex. Now, after about 6 weeks, the knots are starting to bleed through. Is there something I can do about this that won't involve stripping everything down?
sixxmum is offline   Reply With Quote
Old 07-14-2012, 05:30 PM   #2
jschaben
Rewards Points: 502
spot prime the knots with BIN and repaint. Should just need to repaint the spots.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-14-2012, 06:00 PM   #3
Remodeling Contractor
Bin makes several primers.. use the one that is shellac based for this to work
Old 07-14-2012, 06:14 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
This is what you need and nothing else but
The Following User Says Thank You to chrisn For This Useful Post:
ltd (07-14-2012)
Old 07-14-2012, 06:27 PM   #5
jschaben
Rewards Points: 502
Zinsser makes several primers, I didn't know that more than 1 was labeled BIN though
John Schaben
Old 07-14-2012, 06:27 PM   #6
Either one? And no problem with applying over semi-gloss and then semi-gloss on top?
Old 07-15-2012, 11:56 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Actually there are three BIN products now. You have the original white shellac. A clear shellac primer (isn't that just shellac?) And now there is BIN 2, which is a cheaper alternative. It's basically a heavy bodied alkyd that isn't very good for anything they say it is.
Darkling Designs
poppameth is offline   Reply With Quote
Old 07-15-2012, 12:24 PM   #8
jschaben
Rewards Points: 502
Thanks for the heads up on that. I've only seen the original in my area. Not much to pick from around here. ACE hardware, Home Depot and WalMart.
John Schaben
Old 07-15-2012, 12:30 PM   #9
Ok, so I want the one that says ultimate stain blocker and maybe something about shellac?
And I can just put it over the current paint and then repaint on top?
Old 07-15-2012, 12:35 PM   #10
jschaben
Rewards Points: 502
That's all I've ever done. I think the stuff will stick to Jello
You do want to clean it good first, it will stick to dirt just fine but don't know what the dirt will stick to.
John Schaben
Old 07-15-2012, 12:38 PM   #11
Thanks! It's pretty clean only having been painted a few weeks, but I'll give it a wash anyway. I appreciate the help!
Install trim before or after repainting? kredman Remodeling 3 06-08-2010 10:28 AM
Exterior Caulking Suggestions for painted trim to vinyl windows? Learn2Build General DIY Discussions 1 06-04-2010 01:44 PM
Wooden window trim that I stripped looks bad. Suggestions? jpearson311 Painting 15 04-28-2010 10:15 AM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 05:01 PM
Easier way to prep old painted trim? t yearian Painting 9 11-28-2006 04:21 AM
