Knots - Painting - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 04:41 PM   #1
knots
I made 3 door frames in my house useing pine wood 20 years ago, painted it several time back then and the knots bled through. Last years I painted it 4 times in Bear white latex again and damb those knots still show so how long do knots need to dry out and what can I do about sealing them after 20 years??
paquette52 is offline   Reply With Quote
Old 10-23-2012, 06:05 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Bin primer
The Following User Says Thank You to chrisn For This Useful Post:
smalpierre (10-26-2012)
Old 10-23-2012, 06:43 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
I've always had success with Zinsser
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-23-2012, 07:07 PM   #4
Too Short? Cut it Again!
Note that BIN is a shellac based primer and will have strong vapors. Be sure you have adequate ventilation and a respirator if sensitive when using it.
Shellac itself probably would have blocked stains from the knots way back when but BIN is your best bet now.
Old 10-23-2012, 07:50 PM   #5
Rewards Points: 5,974
And also don't forget it takes ammonia to clean your brushes and tools, or clean up spills or drips.
Old 10-23-2012, 08:35 PM   #6
Rewards Points: 20
Yup, Zinsser. Have used it for a number of problem areas, including our own cabin, which we trimmed out with local pine, plenty of knots, and the paint looks great.
Old 10-26-2012, 08:36 PM   #7
Pro
I use denatured alcohol. It's what they say to use - it is a shellac based primer.
smalpierre is offline   Reply With Quote
The Following 2 Users Say Thank You to smalpierre For This Useful Post:
ToolSeeker (10-27-2012), user1007 (10-27-2012)
Sealing pine knots before painting Hardwood Head Painting 5 10-27-2012 11:04 AM
Knots bleeding through new painted trim sixxmum Painting 10 07-15-2012 12:38 PM
Knots in Studs wiz561 Building & Construction 4 08-17-2010 06:30 PM
Knots on baseboards showing through the paint abefroman Painting 9 10-20-2009 04:02 AM
Best primer for preventing wood knots from bleeding through? SandyK Painting 15 02-26-2009 10:25 AM
