Kitchen Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 05-26-2010, 02:07 PM   #1
kitchen ceiling
I had florescent lighting taken out and canned lighting put in..they did a great job making it flat and retexturing..I waited a few days and primed the whole ceiling..I then put one coat of paint on the ceiling. After it dried, there were lines from the painting..not the lighting..only in the area where the new drywall was applied..what should I have done?
Bccook is offline   Reply With Quote
Old 05-29-2010, 07:12 PM   #2
line problem
A little TLC is all that is usually required.
If the DW was patched correctly, you should be able to shine a hand held light from the side, and see no noticeable dips, or height variations. Just hold the light up near the ceiling to wash over the patched area.
Primer application is important-I use 2 coats always on this type of patch. The mud really wants to absorb primer/sealer. cover throughly
Never count on the paint to cover unprimed drywall. It will soak in, and take 3-4 coats to do the job of 1 coat of primer/sealer.
-JL
jlintott is offline   Reply With Quote
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 06:05 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
DIY kitchen cabinets all the way to the ceiling? Jeremy Hillary Boob, PhD Carpentry 7 01-14-2009 07:42 AM
Installing a ceiling fan in the kitchen gerb Electrical 12 06-23-2008 08:49 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
