Kitchen Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 09-21-2006, 01:22 PM   #1
kitchen cabinets
I want to paint my kitchen cabinets, what I have right now is a dark stain wood. Can I paint over the stain? thanks for any suggestions.
jorguez1167 is offline   Reply With Quote
Old 09-21-2006, 03:38 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 502
Sure, use a sealer primer and you'll be fine.
J187 is online now   Reply With Quote
Old 09-21-2006, 05:15 PM   #3
I will do that, sales person at HD said to use a fine sand paper on the wood before applying the primer for better results. Thanks for your help.
Old 09-21-2006, 06:15 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
My Ideal Cabinet Repaint:
Clean with ammonia/water solution
Let dry
Sand with 180
This is to rough up the surface, not sand it off
Wipe with Tack Cloth
Prime with shellac based primer
Let dry
Sand with 180
This is a light sanding to smooth out the shellac a bit
Wipe with tack cloth
Paint first coat, with a proper brush, quality oil-based, high gloss enamel
Let dry over night
Sand with 220
Second coat quality oil based high gloss enamel, also with a brush
Enjoy beautiful cabinets
*Substitute quality oil-based primer and quality waterborne enamel as needed/preferred
Also, I'd recommend going to a paint store rather than a paint dept.
You'll get much better product that will help your project go much quicker and look much better
slickshift is offline   Reply With Quote
Old 09-22-2006, 10:42 AM   #5
how much of ammonia per water solution? 50/50
Thanks slickshift
Old 09-22-2006, 07:11 PM   #6
slickshift's Avatar
Yup
No problem, anytime
Old 09-30-2006, 10:53 PM   #7
diy retard ;)
><(((jan(((D>'s Avatar
i started to do my cabinets today. the shellac primer (i used BIN) was awkward to work with. kind of runny. and it dried almost TOO fast. everything looks blotchy, but i'm assuming once i put on the real paint it will look better. our kitchen looks like an institution now, since EVERYTHING is white now hahaha
><(((jan(((D> is offline   Reply With Quote
Old 10-01-2006, 03:19 PM   #8
slickshift's Avatar
Yes, it is
Yes, it is
Yes, it does
Yes, it does
Yes, it will
Yes, it will
It's kind of stinky too
I hope you had some windows open
It's really the best "surefire" way though (the BIN I mean)
The oil primer will work for a lot of them
But the BIN always works
Installing Kitchen cabinets help helpless handyman Carpentry 16 07-07-2007 07:12 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
installing kitchen cabinets ncoppola09 Carpentry 9 01-06-2007 10:07 PM
tin walls and kitchen cabinets MKemnitzer General DIY Discussions 6 01-05-2007 04:47 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
