-   -   kitchen cabinets (http://www.diychatroom.com/f4/kitchen-cabinets-4010/)
jorguez1167 09-21-2006 01:22 PM
kitchen cabinets
I want to paint my kitchen cabinets, what I have right now is a dark stain wood. Can I paint over the stain?:wink: thanks for any suggestions.
J187 09-21-2006 03:38 PM
Sure, use a sealer primer and you'll be fine.
jorguez1167 09-21-2006 05:15 PM
I will do that, sales person at HD said to use a fine sand paper on the wood before applying the primer for better results. Thanks for your help.:thumbsup:
slickshift 09-21-2006 06:15 PM
My Ideal Cabinet Repaint:
Clean with ammonia/water solution
Let dry
Sand with 180
This is to rough up the surface, not sand it off
Wipe with Tack Cloth
Prime with shellac based primer
Let dry
Sand with 180
This is a light sanding to smooth out the shellac a bit
Wipe with tack cloth
Paint first coat, with a proper brush, quality oil-based, high gloss enamel
Let dry over night
Sand with 220
Second coat quality oil based high gloss enamel, also with a brush
Enjoy beautiful cabinets
*Substitute quality oil-based primer and quality waterborne enamel as needed/preferred
Also, I'd recommend going to a paint store rather than a paint dept.
You'll get much better product that will help your project go much quicker and look much better
jorguez1167 09-22-2006 10:42 AM
how much of ammonia per water solution? 50/50
Thanks slickshift:thumbsup:
slickshift 09-22-2006 07:11 PM
Yup
No problem, anytime
><(((jan(((D> 09-30-2006 10:53 PM
i started to do my cabinets today. the shellac primer (i used BIN) was awkward to work with. kind of runny. and it dried almost TOO fast. everything looks blotchy, but i'm assuming once i put on the real paint it will look better. our kitchen looks like an institution now, since EVERYTHING is white now hahaha ;)
slickshift 10-01-2006 03:19 PM
Yes, it is
Yes, it is
Yes, it does
Yes, it does
Yes, it will
Yes, it will
It's kind of stinky too
I hope you had some windows open
It's really the best "surefire" way though (the BIN I mean)
The oil primer will work for a lot of them
But the BIN always works
