Old 05-31-2010, 10:39 PM   #1
Question
Kitchen cabinet project - long post - sorry!
Hi there. I am slightly challenged when it comes to DIY projects; I apologize in advance!
I have oak, raised panel cabinets in my kitchen, and I hate them. I am not a fan of the grain of oak. I have done a bit of research (slightly OCD! ) and have found enough support to suggest that Fine Paints of Europe would yield the best results.
The directions/steps are somewhat contradictory, though. So, as I understand it, I have to:
1. remove the doors/drawers
2. clean with a solution of warm water and mild detergent
3. Either lightly sand with 220 or use liquid stain remover
4. wash & dry cabinets again
5. Because I want to hide the grain, apply a coat of the FPE brushable putty with a regular brush
6. Once dry, sand lightly with 220 to achieve smooth finish
7. If necessary, repeat #6.
This is where I get confused. I have read that at this point, I can now apply the FPE Eco paint. I have also read, though, that I still need to use a primer over the brushable putty, then apply the paint. Sand between coats of paint, applying two coats.
So, I am not sure if I need a primer over the brushable putty or not. Also not sure if I am going to be sanding more than I need to!
Paint the doors while flat and then prop up so they dry vertically? Use a sprayer or rollers or brushes? I have never painted anything before, as I am sure is obvious! Any advice for a newbie is appreciated! Thanks in advance!
RMA1234 is offline   Reply With Quote
Old 06-01-2010, 04:46 AM   #2
paper hanger and painter
chrisn's Avatar
If you have NEVER painted anything before I would highly recommend you either hire a painter or get some help from someone with experience. You are already spending a whole pile of $ on FPE ( totally unnecessary IMO).Kitchen cabinets are some of the hardest things to paint properly.Get some help, you are not going to get enough information here to do the job correctly.There are things you can do with info received over the internet, painting kitchen cabinets properly for the first time painting would not be one of them
chrisn is online now   Reply With Quote
Cutting laminate kitchen cabinet blueturtle Carpentry 3 11-11-2009 02:37 PM
Kitchen Cabinet Toekick color cellophane Interior Decorating 3 10-29-2009 04:52 PM
Kitchen cabinet doors LOUSY CARPENTER Carpentry 3 02-01-2009 08:07 PM
Kitchen Cabinet Color srianto Interior Decorating 3 01-28-2009 03:32 PM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 02:05 PM
