Kitchen Cabinet Doors - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 01:52 PM   #1
Rewards Points: 85
Kitchen cabinet doors
Got new kitchen cabinet doors, they are oak with redwood stain.
Should i vanish or polyurethane them to protect from fading, discolor or wear?
Have anyone of you done this?
quincy is offline   Reply With Quote
Old 03-01-2011, 02:40 PM   #2
Rewards Points: 258
Hey quincy,
Yes, I have done it to our own kitchen, but I used lacquer because I can. This is where polyurethane SHOULD be used instead of varnish, however a top quality poly should be used. Either Minwax or Pratt & Lambert "Varmor" would be your best bet. The Minwax has a 51% urethane content and the P&L has a 48% urethane content. This is no place to skimp. A varnish can have a 5% urethane content and be legally labeld polyurethane. Which would you rather have? By the way, both Minwax and P&L are both floor polyurethanes. You don't get much tougher than that. Two maybe three coats should last you till retirement age.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
The Following User Says Thank You to spraygunn For This Useful Post:
quincy (03-02-2011)
Old 03-01-2011, 04:40 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 386
Not to argue with spraygunn but after lots trail and error on my own home floors over the last 30 years , I have found that Varathane to be the best poly out there, IMHO.
The Following User Says Thank You to chrisn For This Useful Post:
quincy (03-02-2011)
Old 03-01-2011, 06:31 PM   #4
Rewards Points: 258
Varathane is a good product to be sure. I've used many gallons of it and forgot to mention it. Years ago manufactures were required to list their ingredients on the product labels, not so today. I'll have to do some looking to find out the urethane content.
Thanks chrisn
Best of Luck
Steve
Old 03-02-2011, 12:25 AM   #5
chrisn's Avatar
Rewards Points: 386
Thanks chrisn
I must of sat here 10 minutes racking my brain to come up with the name, just to lazy to go out to the garage and look. What is surprising is that I believe Lowe's carries it, one of the very few good products they do carry
Old 03-02-2011, 01:29 PM   #6
Rewards Points: 85
For whom have done this, what sheen did you applied? Semi-gloss or satin?
I am debating between the two.
Thanks in advance.
Old 03-02-2011, 06:08 PM   #7
Rewards Points: 258
Hey quincy,
That choice is personal preference, however the higher the sheen usually the harder and more durable the finish. My cabinet doors are finished using "hand rubbed effect" lacquer. That's a fancy way of saying semi gloss. I finished two end tables using the same lacquer and they look great.
Best of Luck
Steve
Old 04-01-2011, 03:36 AM   #8
Using lacquer is a nice one I used it for a long period of time for my cabinet, tables and furnitures and I agree to spraygunn that its look great
desiree_furman is offline   Reply With Quote
Old 04-01-2011, 08:45 AM   #9
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I would use Duraseal poly. It can be found at Sherwin Williams and online. We have used Minwax and other polys for years, but have found the Duraseal line to be better. We have a floor refinishing division and only use Duraseal sealers, stains, and poly. Even on a gymnasium floor I would use Duraseal, that's how tough of a product it is.
housepaintingny is offline   Reply With Quote
Old 04-01-2011, 10:43 PM   #10
Spraygunn
Im curious, where did you get the Minwax contents. None of the website show its.
StevenH is offline   Reply With Quote
Old 04-02-2011, 09:11 AM   #11
Did yu buy them finished? why would you have to add a clear top coat?
beerdog is offline   Reply With Quote
Old 04-03-2011, 07:12 AM   #12
Rewards Points: 85
beerdog
Your question to me? If yes then yes we bought them finished, want clear coat to protect them from wear and fading.
Old 04-03-2011, 08:25 AM   #13
Are you sure they are only stained? They may already have factory applied top coat.
Old 04-04-2011, 02:36 PM   #14
Rewards Points: 85
Not sure if only stained or top coat apply, any test to find out if top coat applied or not?
Painting grooves in kitchen cabinet doors. jcraw84263 Painting 5 11-10-2011 12:05 PM
Kitchen cabinet / hinges question mungbeans Kitchen & Bath Remodeling 2 01-25-2011 10:47 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
Kitchen cabinet doors jad Kitchen & Bath Remodeling 2 04-13-2010 08:35 AM
Suggestions on Kitchen Cabinet Update heatherlrex Remodeling 3 04-07-2010 04:23 PM
