Kitchen & Bathroom By Mistake - Painting - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 09:55 PM   #1
Kitchen & Bathroom by mistake
Hi there,
I'm hoping someone might be able to help me.
I stupidly used the wrong paint. I have a kitchen & bathroom mix which I used and a plain Matt in the same colour that I have been using.
I touched up some spots in my spare bedroom, mainly cutting in, and used the kitchen & bathroom instead of the matt paint. It's the same colour but it has a slight sheen to it so looks like I have gone over with a semi gloss.
Ive tried going straight over it with the matt paint and also tried sanding it back and then going over it but I can still see the difference.
Is there a way I can fix this?
Thanks!
girl888 is offline   Reply With Quote
Old 06-16-2012, 10:48 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Touch ups in any sheen are hard, and how the light hits it magnifys it.
The best way is to use the same type of applicator ( use a mini roller if it is a rolled area, and use the same thickness of nap if you can.) that you are going to match. feather it out so it is not an abrupt stop.
If you already used a brush with the higher sheen- you have already made a smoother part.
If it is really bothersome the best thing to do is actually to repaint the whole wall. We pros do this to solve a patch all the time.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-16-2012, 11:16 PM   #3
Hi Brushjockey,
Thanks for the reply! It's on a rolled wall but the parts I did in the wron paint were all with a brush as it was touching up the cutting in.
I will try to blend it in and see how it looks otherwise when you say reprint the whole wall I'm guessing you mean with the glossier paint?
Thanks again!
Old 06-16-2012, 11:18 PM   #4
Repaint it with what the wall was .
Old 06-17-2012, 07:04 AM   #5
Great, thanks!
2 Bathrooms and a Kitchen KevinACrider Project Showcase 16 10-31-2011 07:03 AM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 10:45 PM
10x10 Kitchen Set Work in this Kitchen ryanb4614 Remodeling 3 08-25-2011 08:48 PM
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 07:41 PM
kitchen and bathroom remodeling Grumpy Remodeling 11 02-10-2005 02:35 PM
