Kind Of Sorry I Started This Project... - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 01:31 PM   #16
Rewards Points: 530
soaking the glue a while to soften and then sanding
You tried to sand wet soft adhesive? Sounds like a lot of gummed up sandpaper. I would only sand dry glue/adhesive.
I don't really understand why so many recommend Gardz when oil based Kilz has always seemed to work for me in these situations.
But anyway, the guys are giving good advice, imo, on the procedure to skim this wall.
Hope you do not stress a lot over this as it might be a little taxing on your nerves if it is something new to you.
Good luck.
Old 09-15-2011, 01:33 PM   #17
Rewards Points: 530
What part of the country are you in Libby? South here. Alabama to be more exact.
Old 09-15-2011, 05:03 PM   #18
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
Good luck.
Why use that stinking, brain cell killing stuff when Gardz will do the same thing???
Old 09-15-2011, 08:19 PM   #19
Rewards Points: 530
Heheh, accomplish the same goal with less money. Well there is the brain killing angle. Respirator?
Use enough of it, and you will not even think about it.
Old 09-15-2011, 08:31 PM   #20
Rubbin walls since'79
Brushjockey's Avatar
Gardz goes 3 times as far- next argument?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-16-2011, 02:26 AM   #21
chrisn's Avatar
Rewards Points: 396
Old 09-16-2011, 07:41 AM   #22
Rewards Points: 530
Started removing popcorn ceilings then found out there was 2% asbestos. Am I at harm? Peawhy Remodeling 15 12-30-2010 12:05 PM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 05:39 AM
painting project, large home interior - need planning help bokeh Painting 9 11-06-2010 09:45 AM
Approximate cost for entire project? tnis0612 Building & Construction 11 02-26-2009 10:33 AM
