Kind Of Primer - Painting - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 01:25 PM   #1
kind of primer
hi i just removed the wall paper from my kitchen what kind of primer do i need to use before painting the walls.
maria1200 is offline   Reply With Quote
Old 06-07-2012, 06:36 PM   #2
Gymschu's Avatar
Rewards Points: 480
Maria it depends. If you did a great job of removing the paper and the adhesive from the walls so that they are clean and were previously painted, you really won't have to prime. If the walls are dinged up and need some patching, etc. you will need a quality latex drywall primer. If the walls are clean but glossy, a bonding primer would work better.
Old 06-07-2012, 07:32 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
When I remove paper, clean the past off, I always prime with Gardz to seal in any residue that may have been missed, any damaged areas are made solid for repairing, good primer for any top coat.
An oil coat ( like cover stain) would do the same, Gardz is easier.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-07-2012, 08:04 PM   #4
I have always used BIN 123 Primer after wallpaper removal. It is water based and the finish coat looks great and no paste burn through. I never prime and paint the same day. I allow 24 hrs to dry .
Hymie is offline   Reply With Quote
Old 06-08-2012, 03:36 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 230
One of these days it will bite you in the *ss, 123 is NOT recommended for this, old residual paste WILL come through it. Might take a day, week, year, but it will.
Gardz or oil only for this situation.
what kind of primer do i need sh417 Painting 5 02-08-2011 05:00 PM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 10:06 AM
Zinsser primer not drying kevinkk Painting 9 12-17-2009 09:56 PM
Oil based Primer? Kotik Painting 2 12-06-2009 10:57 AM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 01:54 AM
