Kilz Premier Primer..needs Priming? - Painting - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 03:08 PM   #1
Rewards Points: 89
Kilz premier primer..needs priming?
I'm in the middle of a renovation. In help this along my father primed my walls with this crap. I have some areas that I need to be redone, pointed, skim coated.
Do I need to go over the entire wall with primer I repair?
Do I need to use that same primer?
I have an area that I used kilz2 next to this kilz premier and you can tell the difference, I'm scared the light paint color we are going to use, will finish differently?
Anything else I should do prior to paint?
Thanks so much for the help!!!
chipraynor is offline   Reply With Quote
Old 04-12-2012, 04:23 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 300
Kilz would not be my choice but you should be OK. I would at least go over any new skimming you did and depending on the paint and sheen maybe the whole wall. If you are using flat then 2 full coats will do.
Old 04-12-2012, 09:02 PM   #3
ARC Painting's Avatar
The main thing is to have the patched areas sealed, so that the finish coat will absorb consistently across the whole wall.
Walls can have an orange peel texture from previous coats, but patched and sanded areas are much smoother, so sealing with primer will encourage uniform texture.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Kilz Primer on plywood chong Painting 8 07-28-2011 04:35 AM
Kilz Latex Primer & Aura Finish Coat? HenryG57 Painting 7 06-02-2010 03:41 AM
Spray primer Kilz latex now all finish paint is soft and easily peelable dorothyolive Painting 29 11-02-2008 05:14 PM
Kilz Primer Question brookeH Painting 2 01-26-2008 09:06 AM
