Kilz Latex Primer & Aura Finish Coat? - Painting - DIY Chatroom Home Improvement Forum
Old 05-19-2010, 11:02 PM   #1
I am having a semi-pro painter paint our master bedroom and loft in a few days. I will be going with a paint color quite similar to what we have now, which has lasted nicely for over 10 years. I will be buying the paint myself and I want to go with Aura eggshell finish paint. Although they advertise to need only one coat, I tried it out in some small areas and it is best to go with two coats. Our painter, however, recommended that he use Kilz latex as the first coat (tinted to the same color as the Aura) and then one coat of Aura as the finish coat. I challenged the fact that we have no significant stains, but he says Kilz is great to use even if I don't have stains. He "swears" that I will love the result. He has never worked with the Aura product. Should I follow his advice and do Kilz latex tinted followed by one coat of Aura (even though primer is not really needed and I don;t have stains that would call for a Kilz product)? Or skip the Kilz and go with two coats of Aura? (And if I go with the Kilz - use the latex or go with the more effective oil based product?)
Thanks!
HenryG57 is offline   Reply With Quote
Old 05-20-2010, 04:08 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
Skip the Kilz, 2 coats Aura and it's done
Old 05-20-2010, 09:26 AM   #3
i think he's trying to save u some money. when i used to sell paint, i did this a lot. basically, primer (especially kilz) is a LOT cheaper than aura. the idea here is if you use a primer tinted to the paint color for the base coat and one coat of paint, you will have saved money. this is only true if you are going to have to use more than 1 gallon total of the high-priced paint.
previous poster is correct though, two coats of Aura would be just fine.
noboru wataya is offline   Reply With Quote
Old 05-20-2010, 11:17 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Two coats of Aura would be better period. Kilz primers are not good products. Only the original oil is halfway decent. The latex versions have a rather high failure rate.
poppameth is offline   Reply With Quote
Old 05-20-2010, 01:30 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
I like Kilz 2 Latex, but it is not needed here especially since you aren't changing the color much.
Old 06-01-2010, 02:48 PM   #6
Painter/Paint Dealer
Finally, someone with some sense. I swear Kilz only sells because of its name. As far as I'm concerned, its garbage.
The Paint Doc is offline   Reply With Quote
Old 06-01-2010, 07:01 PM   #7
WindowTreatment Installer
I would use a tinted primer as the first coat. The reason is if the walls haven't been painted in 10 years, then chances are they're very dry. The primer will seal the walls better than paint, so the second coat will absorb evenly.
bobtheblindguy is offline   Reply With Quote
Old 06-02-2010, 03:41 AM   #8
chrisn's Avatar
Rewards Points: 606
Latex Kilz products are a risk that is not needed
The painter having no experience with this product could be problematic,have you asked him how much experience he has had?I would be worried about that.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Spray primer Kilz latex now all finish paint is soft and easily peelable dorothyolive Painting 29 11-02-2008 05:14 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
