Kilz 2 For Exterior? - Painting - DIY Chatroom Home Improvement Forum
Old 09-26-2007, 01:05 PM   #1
Do, undo, then do right
BilHam's Avatar
Kilz 2 for exterior?
Can I use the latex Kilz 2 for sealing clapboard and patches before painting? Or is oil based best?
BilHam is offline   Reply With Quote
Old 09-26-2007, 01:57 PM   #2
Rewards Points: 506
Latex primer is good, but for the sake of your sanity, not Kilz2! All Kilz products other than the original oil-base do not have a good reputation here.
What I would do is head to your local paint store (like Sherwin Williams or Benjamin Moore) and ask the friendly folks behind the counter what you should use to go with the high-quality paint you will be buying from them. They should be able to tell you what will go well with your paint choice.
SirWired
sirwired is offline   Reply With Quote
Old 09-26-2007, 03:09 PM   #3
Rewards Points: 774
Oil based is best of exterior applications, but as long as the paint says it can be used in exterior settings, you should be okay.
cibula11 is offline   Reply With Quote
Old 09-26-2007, 03:17 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Don't use the Kilz 2
...ever
But yeah you really want oil for this application anyway
slickshift is offline   Reply With Quote
Old 09-26-2007, 07:45 PM   #5
Workaholic's Avatar
Rewards Points: 268
I agree an exterior oil primer for exterior.
Kilz2 is a poor product.
Sean
Workaholic is offline   Reply With Quote
Old 09-26-2007, 10:41 PM   #6
BilHam's Avatar
Thx
Old 09-28-2007, 04:09 AM   #7
Humorous Illustrator
funnyguy's Avatar
If you prime with oil based paint, you can't finish with acrylic laytex. Acrylic will not adhere to oil. You can put oil on top of acrylic, but not the other way around.
funnyguy is offline   Reply With Quote
Old 09-28-2007, 05:55 AM   #8
Guest
Guest
Posts: n/a
Acrylic will adhere to oil just fine if prepped correctly, especially when talking about primer. Put oil over acrylic without proper preparation and you could be in for a world of trouble. Primers are completely different beasts than paint anyway in this case.
Old 09-28-2007, 06:40 AM   #9
slickshift's Avatar
This is a common misconception
In fact, using an oil based primer and a latex top coat is a common problem solving technique...the technique for many apps
Painting process kimct77 Painting 7 09-24-2007 06:02 PM
painting & prep-- Slickshift? sundog Painting 10 01-17-2007 07:32 AM
Covering pet odor with laminate kjmenchio Flooring 6 01-16-2007 05:33 AM
Kilz ? kenziekiss Painting 23 11-12-2005 03:50 PM
