Killz Premium Primer Question - Painting - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 06:18 AM   #1
I am using the water based Killz Premium Primer to cover old paint in a bedroom. The walls were purple and trim yellow. Its did a good job of covering. Once I repainted the walls though my wife said she wanted to leave the trim white so I just put 2 coats of the Killz on the trim and she liked it. Now I am wondering if leaving just the primer on the trim is ok. Should it be painted over to reduce VOCs or for another reason or is it ok as it is?
Steveski54 is offline   Reply With Quote
Old 03-04-2013, 07:50 AM   #2
Gymschu's Avatar
Rewards Points: 1,032
I suppose if you and your wife like it the way it is........well, you can leave it that way. It is not acceptable paint technique to leave primer and not apply paint over it. Primer usually is flat or nearly flat so any dirt, dust, etc. is gonna quickly attach itself to this primered woodwork. A nice semi-gloss paint would finish out the job........
Old 03-04-2013, 09:13 AM   #3
Rewards Points: 14,312
Primmers are also poris. Add some finish paint.
Old 03-04-2013, 02:28 PM   #4
Painting Contractor
rbriggs82's Avatar
Rewards Points: 77
It may look good now but in a couple months it's gonna get dirty and impossible to clean. Paint it with a semi-gloss or satin paint.
rbriggs82 is offline   Reply With Quote
Old 03-04-2013, 02:40 PM   #5
ccarlisle's Avatar
Oh yeah?
I thought primers were mostly resin and paints mostly pigments...if so, that would make primers less porous no? And why are there primers for porous materials like wood and concrete? What do you mean "they're porous", anyway?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-04-2013, 03:07 PM   #6
cdaniels's Avatar
Primers are rough.You need a slick finish that won't catch every molecule of dust.Do yourself a favor and put at least one coat of enamel on it, two would be best.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-04-2013, 03:15 PM   #7
Rubbin walls since'79
Brushjockey's Avatar
? Some are, many are not. Most primer sealers like Zin 123, Smart Prime, etc are almost an eggshell sheen when dry. Hard and smooth. But they are not meant to be left uncoated. They are made so the top coat can grab a hold on them, and dirt can also.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 3 Users Say Thank You to Brushjockey For This Useful Post:
cdaniels (03-04-2013), Gymschu (03-04-2013), rbriggs82 (03-04-2013)
Old 03-04-2013, 06:28 PM   #8
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Primers are problem solvers and serve different purpose, as under coaters. Primers are not designed to be used as a top coat. Most primers need to be top cated with a paint finish within 30 days. Paint serves the purpose of protection to a surface and ascetics. Primer is not durable or washable like a quality paint is. I would apply a quality paint over the primer.
housepaintingny is offline   Reply With Quote
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 06:16 PM
TO PRIME OR NOT TO PRIME that is the question ToolSeeker Painting 7 09-29-2012 07:57 AM
Primer question mikethefinfan Painting 2 08-15-2012 07:19 AM
Please help! I'm repainting bedroom furniture and primer is "gunking"! Fun2Learn Painting 12 02-13-2012 06:54 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
