Joint Shadows After Priming - Painting - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 11:33 PM   #1
joint shadows after priming
Just primed my basement walls after sheetrock was compounded and sanded thoroughly and smooth as silk. only have 4 pull chain lights(just light bulb hangin down) at this point and certain areas of room light shines down and i can see joint line from top to bottom in various areas. I understand the sanded joint compound is shinier and primer didnt seep into it like the wallboard thus the shadowing. bought premium flat paint to finish walls./will this cover these areas and eliminate/ cover the shadows?
duck62 is offline   Reply With Quote
Old 08-09-2011, 04:11 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Most likely, unless you used crappy primer and are going to use crappy paint.
Old 08-09-2011, 05:51 AM   #3
Welcome Duck, flat would be the best option for hiding imperfections. However, shadows are created by light going across an imperfect surface. As good as your seams may be, they are still an irregularity on the surface, and they aren't going to fool the light. Coat it out and see what you've got. What else can you do at this point? You may find they disappear completely or at least become something you can live with or mask some other way.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
CBU Joint Issue? cobrakai Kitchen & Bath Remodeling 1 01-19-2011 10:11 PM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 04:57 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Finished priming, but I still see shadows underneath...? yummy mummy Building & Construction 2 02-19-2009 09:15 AM
