Joint Compound Vs. Spackle - Painting - DIY Chatroom Home Improvement Forum
Old 09-13-2007, 01:56 PM   #1
Rze
Average Joe
Rewards Points: 79
I used to think that Joint Compound and Spackle were interchangable. I just read somewhere that Spackle should be used for small holes, Nail holes etc, and JC for larger applications. I have a wall that needs a "skim coat" to even it out for painting. Shoudl I use JC or Spackle? Or is there another Alternative?
Thanks!
Rze is offline   Reply With Quote
Old 09-13-2007, 03:15 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Not the same thing/interchangable
You'll want to use Joint Compound for skim coats
slickshift is offline   Reply With Quote
Old 09-13-2007, 08:38 PM   #3
Workaholic's Avatar
I suggest a light weight joint compound.
Sean
Workaholic is offline   Reply With Quote
Old 09-13-2007, 08:48 PM   #4
Skim Coat? Joint compound... be sure your water does not have iron content.
Big Bob is offline   Reply With Quote
Old 09-13-2007, 10:35 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As already mentioned; Joint compound for anything larger than a penny sized issue.
- Build Well -
Old 09-15-2007, 12:09 AM   #6
Rze
Average Joe
Rewards Points: 79
Thanks All!
premix joint compound vs setting type ITE Drywall & Plaster 32 03-12-2014 05:04 PM
Teflon tape or teflon pipe joint compound? zel Plumbing 1 04-02-2007 10:54 PM
What brand of Joint Compound? mwehnes Building & Construction 6 03-26-2007 08:11 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
joint compound question golfer General DIY Discussions 3 01-09-2006 07:19 AM
