Joint Compound? Spackle? Or Something Else? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 08:16 AM   #16
Originally Posted by Amycat View Post
Also, what do you recommend for washing the exposed drywall? It's a bit slimy when wet -- there is still some old glue that I need to get off before priming.
Thanks.
You need to remove the old residual wallpaper glue (ie slime) before painting. Use vinegar mixed with the hottest water you can stand and use a scotch brite pad to scrub. When the slime is gone rinse the wall.
Use an oil based primer.
hennyh is offline   Reply With Quote
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 05:09 PM
Use joint compound, spackle, something else?? tracyballard Carpentry 0 06-08-2010 10:39 PM
Used spackle instead of joint compound on a wallboard repair--help TytusDwn General DIY Discussions 4 10-25-2009 03:43 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Joint Compound Vs. Spackle Rze Painting 5 09-14-2007 11:09 PM
