Joint Compound - Painting - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 07:30 AM   #1
Joint Compound
Hey All,
We have recently moved into our home. I am about to begin painting the walls of one of the bedrooms where I found joint compound spots all over the wall that were never sanded down. Additionally, they have been painted over. Any suggestions for a fast removal of these? There are about 20-25+ around the entire room. I was thinking of just getting a small sheet pad sander to get them down and then going over them with a block/sandpaper. Your thoughts greatly appreciated.
kenm09 is offline   Reply With Quote
Old 03-23-2010, 11:04 AM   #2
Rewards Points: 526
That will work. I would use a random orbital sander with 100 grit paper and a sanding sponge, but either way will be fine. You may need a thin fill of mud after you sand, depending on how the paint film breaks down.
Windows is offline   Reply With Quote
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 05:09 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 05:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 05:57 PM
