Jasco Paint Striper - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2014, 05:50 PM   #1
jasco paint striper
i just used some jasco premium paint and epoxy striper to remove some paint off some metal.Worked good now i whant to repaint.I just do not know what to use to clean the surface with. I used isopropyl alcohol. Will this work It does not say any thing on the can. Thanks for any response
northcal is offline   Reply With Quote
Old 02-23-2014, 10:31 AM   #2
Painting Contractor
Rewards Points: 87
I think Jasco can be washed off with water, but that may rust your surface. The alcohol sounds like a good idea, and steel wool substitute (3M pad) to rub off any remaining residue. The volatile chemicals that do the stripping would have all evaporated off already.
kkeith is offline   Reply With Quote
The Following User Says Thank You to kkeith For This Useful Post:
northcal (02-23-2014)
Old 02-23-2014, 11:58 AM   #3
Soap and water should work, correct me if I'm wrong but I think the can says the same.
Edit, ya just checked the website. Soap and water
Mbjason is offline   Reply With Quote
Old 02-23-2014, 04:38 PM   #4
ok thanks i used the spray paint can it does say work area and tools can be cleaned whith soap and water thank you
Old 02-25-2014, 03:58 PM   #5
I've used lacquer thinner with good success.
clambake6 is offline   Reply With Quote
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
