JASCO Paint Remover - What's The Trick? - Painting - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 12:43 PM   #1
JASCO Paint remover - what's the trick?
I am trying to remove 2 layers of old paint from a door. The paint store sold me JASCO's paint removal product. I brush it on, it certainly bubbles up MOST of the paint, I wait for it to work for a while (8-10 mins.) and scrape and scrape. It took 4 coats and 2/3 of the can to get the 1st side of the door (and it's still not perfect). If I wait longer than 10 mins., it appears to start drying to quickly.
What's the trick to this process? Is there a better product?
Thanks in advance.
cody21 is offline   Reply With Quote
Old 08-11-2009, 12:20 PM   #2
NAV
there are many different ways you can strip paint.
you can burn it off - works the best but dont burn your house down
you can use a product called Peel Away - single application stripper that will pull something like 12 coats off in one application. i have used it and it works but read the directions. they have different types and some need to be neutralized after
you can use the method you are doing now. if you leave the stripper on longer and it starts to dry just apply more stripper to keep it wet. it will take multiple applications no matter what
you can just sand off the old coating with sandpaper - be careful not to eat too much lead dust - it will make you stupid
you can send the door out to be dipped - they dip the door in stripper and do all the work for you - it will cost some money
ICI makes a product called Hydorstrip that works well -spray apply let it sit for 12 to 24 hours and pressure wash off
good luck
NAV is offline   Reply With Quote
Old 08-11-2009, 12:28 PM   #3
Thank you.... After some trial and error, I've discovered that I just need patience, and as you pointed out, strip the 1st coat, reapply it again, then Sand it at the end. Just tedious, and I'm not the most patient person.
Old 11-19-2010, 03:34 PM   #4
How to remove paint from heating vents
OK, so along these lines, I want to use Jasco to remove paint from heating vents. I think this stuff should work as well? whaddya think?
meryldean is offline   Reply With Quote
Old 11-19-2010, 03:38 PM   #5
I would think that plain old cheap Paint Stripper would work for heating vents (metal, right?) ..... Not sure if JASCO is "metal safe" ... maybe read the can ...? (I would probably just replace the vents - but that's just lazy me.)
good luck.
Old 11-19-2010, 03:45 PM   #6
paint stripper
Yes on the vents but they are old/odd size and may not be able to be replaced - old house...so good old fashioned paint stripper and yes they are metal. I just want to make sure it works - for a tenant who is very fussy about these things!
Old 11-19-2010, 05:41 PM   #7
Rewards Points: 258
Hey Cody,
Apply the stripper verrrrrrrry liberally then cover the door using one piece of thin visqueen. What this does is stops the air from getting to the remover and it allows the stripper to work longer. Stand back and have a cigarette, dip or a couple of beers. It should come off a lot easier.
Steve
www.handpaintedbysteve.com
spraygunn is offline   Reply With Quote
The Following User Says Thank You to spraygunn For This Useful Post:
cody21 (11-19-2010)
Old 11-19-2010, 05:42 PM   #8
Thanks Steve ... I'll try the the next time.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
