Old 08-15-2007, 12:38 PM   #1
Default Issues w/ SW SuperPaint
This paint is cracking in several areas just over a week from application (see photos).
This is a repaint job. The substrate, which is rough-cut lumber siding with high texture, was scrubbed to remove dirt and mildew spots, dried, repaired, spot primed the areas repaired, dried again, and then painted with SuperPaint. Two coats of paint were applied by brush within two days one from the other, following the instructions on the label. No painting was done in direct sun light.
I am very concerned about the paint cracks and fissures in the highly textured areas because these areas are prone to water accumulation and if wood is exposed it may rot in time if exposed to adverse conditions for long time.
This is a 25-year warranty extaerior paint, and I do not see any reason for it to crack in such a short time after application. Can someone identify the cause of paint cracking?
How can I fix it?
Has anyone else had problems with SW SuperPaint???
Let me know.
Chip
p-chip is offline   Reply With Quote
Old 08-15-2007, 06:07 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
I don't use Super Paint enough to know if that's a common problem or not
I really don't care for the stuff...partly because I often see that sort of thing on exteriors with it...so...maybe that's sort of an answer
If that was prepped properly before the SP, I'm sure a coat of Duration would fix it
slickshift is offline   Reply With Quote
Old 08-15-2007, 09:47 PM   #3
Is Duration a much better paint than Super Paint?
(We're trying to decide which one to use, so I'm keeping an eye on this thread.)
mwewriter is offline   Reply With Quote
Old 08-16-2007, 12:47 AM   #4
Paint/Faux Artisan
Da Vinci's Avatar
Was the siding brand new resawn or old? Was it pressure washed prior to painting and if so how long did it dry before painting? What kind of primer did you use? How many coats? How heavy of a coat was applied? Sprayed? Back brushed? That will help to determine possible reasons...
Bay Area Painting Company
Ooops- sorry- reread post- some answers there already. What kind of patching was used?
Da Vinci is offline   Reply With Quote
Old 08-16-2007, 02:07 AM   #5
I used PL400 to fill up nail holes, and exterior caulking for cracks.
Old 08-16-2007, 09:44 AM   #6
slickshift's Avatar
Yes
Absolutely
Although I mentioned I don't care for Super Paint, I do like Ben Moore's MoorGlo/Soft/Gloss and Pittsburgh's Manor Hall very much
Duration is even better then those
It is thick, and some don't care to work with it, but it is superior
Old 08-16-2007, 12:08 PM   #7
Have you worked with Manor Hall Timeless at all? How does it compare to Duration?
(I tried to PM you, but I only have four posts, so DIY won't let me.)
Old 08-16-2007, 02:12 PM   #8
slickshift's Avatar
No, I have not
I was not aware that Timeless was a sub-line of Manor Hall
Pittsburgh doesn't have a ton of support out here (I'm basically on an island), so it's tough to get new info and product
As happy as I am with manor Hall, I wouldn't hesitate to try a sub-line of it
Old 08-17-2007, 09:17 PM   #9
jms
Default super paint
I cant say for sure without doing a little investigating or scrapping but it looks like this is the substrate repair problem not paint problem.SP is a 25 year warranty but the repair has to be also a 25 year warranty and done right.
If the substrate pulls loose then what ever is on top of it also pulls loose.
I have never seen SP form cracks like that for no reason. SP will protect your substrate very well but will not fill in cracks.Hope this helps a little.
jms is offline   Reply With Quote
Old 08-19-2007, 10:48 PM   #10
slickshift's Avatar
Good point
Paint colors, it doesn't fill
More On This Topic
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
How to Texture a Ceiling
How to Texture a Ceiling by Expert Village
This is Kevin at Expert Village. We are going to get a big lump of ceiling texture and apply it. Sometimes we really can't get enough on the roller and if you find you can't get enough on your roller, you need to bring it up and apply it directly. You... Read More »
You can give a brand new wall the appearance of old crumbling stones. Choose the walls where you want to paint this effect, and then follow these directions. Be prepared to spend a couple of days completing the project. The finished result is well worth... Read More »
Okay, our next step for painting the kitchen is to fix all of these cracks that are occurring along the edge of the trim. And we do that with the caulking. So let me show you how to get that started. You want to keep a pail for clean up because it gets... Read More »
This is Kevin at Expert Village and we are going to texture a ceiling. I just removed this from a ceiling so that we can get a clear shot at the cracks up there. The texture would not have sealed over this hanging and regluing it was a bad idea. You can... Read More »
Exterior Paint: Duration, Superpaint, Manor Hall, or Timeless? mwewriter Painting 5 08-15-2007 08:05 AM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 07:52 PM
Differences between SW Duration, Superpaint and Cashmere? Autumnknight Painting 2 03-08-2007 10:55 PM
Grounding Issues in a 1849 House Contractor's_Daughter Electrical 6 11-20-2006 12:56 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
