Interior Trim Paint - Painting - DIY Chatroom Home Improvement Forum
Old 11-21-2011, 08:29 AM   #1
interior trim paint
I am painting all the trim and doors in my house. They are currently stained. My problem Is , I dont like the shine level in the oil based paint that most paint stores and painters say I need to use.Even in lo luster, the oil base is really shiney. Can i use a latex satin or eggshell finish on doors and woodwork. And how do I pick the right White for whole house trim?
jhenderson is offline   Reply With Quote
Old 11-21-2011, 10:27 AM   #2
Too Short? Cut it Again!
I would get a good paint store enamel primer/underlay---alkyd or water-based. Then use whatever sheen of acrylic, not oil based trim paint you want. Mix in Floetrol and use a quality 2.5 or 3 inch sash brush (Wooster, Purdy).
Nothing against oil but it does chalk and yellow overtime. Most DIYers prefer water clean-up.
Remember it takes acrylics/latex vinyls 30 days for the paint film to cure to the desired sheen.
As for which white? Really depends on what paint, flooring colors, etc. you have. A bright white can look stark and make some tints look dull. A "too off white" can look dirty against crisp hues. I've used Atrium White a lot in homes with wood floors, stone countertops, and fairly diverse wall colors. I have it mixed to the Ben Moore or Pittsburgh formula.
You should drag home an off white color selector. Ben Moore stores (and I suspect others) will gladly loan you a white fan deck.
Old 11-21-2011, 11:25 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
You realise that the higher sheens will also provide better scuff and dirt prevention, and wash easier..
Try BM satin finishes like Aura . I think that Muralo's satin is very low on the sheen scale if you can find it- excellent paint too.
A box store's eggshell will not be a very good trim paint, imo.
You want hard and cleanable.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-21-2011, 01:12 PM   #4
A Little Of Everything
Rewards Points: 1,364
I agree with sdsester & brushjockey.
Using the right primer is the most important thing here. Without proper adhesion, you've got nothing but a headache. You can then top-coat it with just about whatever sheen you want - and, as these guys have said, use latex.
In pretty much every house my wife & I have renovated, we've used satin finish on the interior walls, and semi-gloss on the trim (if painted).
DrHicks is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
