interior trim paint
I am painting all the trim and doors in my house. They are currently stained. My problem Is , I dont like the shine level in the oil based paint that most paint stores and painters say I need to use.Even in lo luster, the oil base is really shiney. Can i use a latex satin or eggshell finish on doors and woodwork. And how do I pick the right White for whole house trim?
I would get a good paint store enamel primer/underlay---alkyd or water-based. Then use whatever sheen of acrylic, not oil based trim paint you want. Mix in Floetrol and use a quality 2.5 or 3 inch sash brush (Wooster, Purdy).
Nothing against oil but it does chalk and yellow overtime. Most DIYers prefer water clean-up. Remember it takes acrylics/latex vinyls 30 days for the paint film to cure to the desired sheen. As for which white? Really depends on what paint, flooring colors, etc. you have. A bright white can look stark and make some tints look dull. A "too off white" can look dirty against crisp hues. I've used Atrium White a lot in homes with wood floors, stone countertops, and fairly diverse wall colors. I have it mixed to the Ben Moore or Pittsburgh formula. You should drag home an off white color selector. Ben Moore stores (and I suspect others) will gladly loan you a white fan deck. |
You realise that the higher sheens will also provide better scuff and dirt prevention, and wash easier..
Try BM satin finishes like Aura . I think that Muralo's satin is very low on the sheen scale if you can find it- excellent paint too. A box store's eggshell will not be a very good trim paint, imo. You want hard and cleanable. |
I agree with sdsester & brushjockey.
Using the right primer is the most important thing here. Without proper adhesion, you've got nothing but a headache. You can then top-coat it with just about whatever sheen you want - and, as these guys have said, use latex. In pretty much every house my wife & I have renovated, we've used satin finish on the interior walls, and semi-gloss on the trim (if painted). |
| All times are GMT -4. The time now is 09:19 PM. |
