Interior Priming, Spotty Coverage - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 09:07 AM   #16
Rewards Points: 6,034
Originally Posted by chrisn View Post
http://www.homedepot.com/buy/zinsser...aler-2301.html
+ SW should be able to order it for you
SW doesn"t handle any Zinnser products, but Ben Moore does. My local HD doesn't carry it and won't order it, but yet they carry Zinnser, figure that out. I ended up finding it at just a small paint store in the area.
Old 12-24-2012, 02:26 PM   #17
Originally Posted by Matthewt1970 View Post
You are giving conflicting info here. As Brushjockey mentioned Primers are not for covering colors. Any patched areas will need 3 coats or they will not match the existing wall. It is always best to have your first coat be primer and then a coat of paint (both of those can be on just the areas patched), and then a final coat over the entire wall. One coat of primer and one coat of paint is rarely enough, especially with an eggshell or semi-gloss paint.
I can see how it comes across conflicting... When you say three coats, do you mean spot prime and then two full coats on the entire wall or just the spot primed area?
Adrenalinejunky is offline   Reply With Quote
Old 12-24-2012, 02:58 PM   #18
Rubbin walls since'79
Brushjockey's Avatar
..read his post again..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
What does 100% tile coverage mean? JFERTICH Flooring 0 10-14-2012 12:11 AM
home inspection with rissue re roofing and possible denial of isurance coverage msbnurse Roofing/Siding 7 05-05-2012 11:18 PM
Primer/paint coverage over old stucco stromer3 Painting 1 05-05-2010 10:47 AM
Need some ideas on maximum coverage paint shaan71 Painting 1 03-09-2009 11:49 AM
Paint With Best Coverage? RbrtPtikLeoSeny Painting 2 05-02-2008 09:44 PM
