Interior Oil Based Paint Then Latex Exterior - Painting - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 09:10 AM   #1
Interior oil based paint then latex exterior
Can I use interior alkyd primer first then latex exterior for an exterior project? I need to paint a boat house and I have a gallon and a half of interior alkyd primer. If I can use that on an exterior paint project rather than buying another gallon of primer, that would be great. Can someone give me some advice
katiegr is offline   Reply With Quote
Old 06-07-2012, 11:10 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by katiegr View Post
If I can use that on an exterior paint project rather than buying another gallon of primer...
Buy another gallon of EXTERIOR primer
Old 06-07-2012, 01:00 PM   #3
Mr. Paint's Avatar
Interior and Exterior primers are engineered for different properties and purposes. The temptation to think they're all alike is understandable. An exterior alkyd primer has better penetration and better moisture resistance.
You can buy an Interior/Exterior acrylic primer such as Zinsser 1-2-3. This is a high-adhesion, fast-dry product that can be used on numerous surfaces.
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
Will22 (06-08-2012)
Old 06-08-2012, 04:23 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Originally Posted by katiegr;938205[COLOR=red
]Can I use interior alkyd primer first then latex exterior for an exterior project?[/color] I need to paint a boat house and I have a gallon and a half of interior alkyd primer. If I can use that on an exterior paint project rather than buying another gallon of primer, that would be great. Can someone give me some advice
Can you? Certainly
Should you? ahhhhh, NO!
Best brand of exterior latex house paint for the deep south Stevoreno Painting 45 11-18-2012 07:55 AM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Is it worth it to spar urethane over flat exterior latex paint? peterk312 Painting 3 04-21-2010 10:15 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
